How do you replace an oil pan gasket on a 2000 civic? - Honda-Tech
Old 09-16-2010, 08:40 PM   #1
xTomei's Avatar
Icon6 How do you replace an oil pan gasket on a 2000 civic?
I have a 2000 Civic LX Sedan w/ Automatic transmission.
I was just wondering what all has to be removed in order to
replace the oil pan gasket.
Also what tools will be required?
xTomei is offline   Reply With Quote
Old 09-16-2010, 08:41 PM   #2
Default Re: How do you replace an oil pan gasket on a 2000 civic?
Socket, scrapper.
Remove oil, remove oil pan, scrap gasket off, place gasket on pan, re - bolt pan.
EJeff8 is offline   Reply With Quote
Old 09-16-2010, 09:37 PM   #3
xTomei's Avatar
Don't you have to remove the exhaust manifold?
Old 09-16-2010, 09:46 PM   #4
Remove exhaust pipe A, the engine stiffener, and the flywheel cover.
You may need a large rubber mallet to knock the oil pan loose from the block.
Use an OEM gasket. Put some silicone sealant at the sharp corners of the pan and gasket on either end. Torque the nuts and bolts to spec in several passes in the order specified in the service manual.
Former User is offline   Reply With Quote
Old 09-16-2010, 11:00 PM   #5
xTomei's Avatar
Do I really have to remove ALL of those? If thats the case, I think id rather pay someone to do it.
Old 09-16-2010, 11:12 PM   #6
Quote:
Nooooooooo don't pay someone! Those parts are pretty easy to remove. Just spray PB Blaster on the exhaust bolts and let them soak for an 30 min before you wrench them.
Old 09-17-2010, 08:31 AM   #7
xTomei's Avatar
Think everything could be removed and replaced in 1 hour?
Old 09-17-2010, 09:20 AM   #8
Jimster480's Avatar
maybe an hour and a half. It depends on how hard the bolts are to get off. But you can buy liquid wrench, and spray EVERYTHING with it and then tap everything with a wrench or extension a few times, and let it sit for about 5-15 mins and it all should come off pretty easily. Are you sure your oil pan gasket is leaking?
Jimster480 is offline   Reply With Quote
Old 09-17-2010, 10:25 AM   #9
xTomei's Avatar
I'm 95% sure its the oil pan gasket. Oil is everywhere on the oil pan. It seems to be coming from the seal. Also its a pretty bad leak.
Old 09-19-2010, 02:51 AM   #10
did mine tonight, wasn't too fun. Now that I've done (and loosened all of the bolts/nuts) I could do it again a lot quicker, but I'd much rather not. FYI, if you plan on replacing the oil pan, go stock, as well as for the gasket. Bought an oil pan from RockAuto and it didn't have the holes for the stiffener brackets or a groove for the gasket. Gasket from Pep Boys wasn't too impressive either, as if it wasn't enough of a pain in the *** already.. No immediate leaks, we'll see how she looks in the morning.
nilleo is offline   Reply With Quote
Old 12-10-2010, 04:23 PM   #11
Anyone have photos and procedure for replacing oil pan gasket on 2002 Honda Civic LX
D17A1 SOHC? Also, torque specs.? (Honda dealership asking $400 to replace gasket...service manager doesn't talk with me after I made comment on price.)
Viejo is offline   Reply With Quote
Old 12-10-2010, 05:31 PM   #12
make sure when you tight them, make sure you tight it enough not too much you might end up breaking the bolts, gl
sw07tc is offline   Reply With Quote
Old 12-10-2010, 05:34 PM   #13
318 Curves, 11 miles
Vindicator9000's Avatar
It would be just about the same as on any d16. Remove exhaust manifold, etc. The d17 is structurally pretty similar to the d16 from all I've heard.
Not sure about the torque specs because I don't have a later service manual, but I know on the pre-2001 cars, it really isn't much. We're talking like 15 ft/lbs. Much more than that breaks them.
Vindicator9000 is offline   Reply With Quote
Old 12-11-2010, 08:38 AM   #14
Thanks. This Civic has taught me to think about many things before I buy another car,
one being to get one that I can under to work on; this thing is so low it scrapes chewing gum off the street. I lifted it up with a couple of hydraulic floor jacks and took a look-see. A person with limited use of one arm probably shouldn't attempt this job. I'd better get some help or take the car to one of our local one star shops, which will charge $200. Anyway, the leak is only a teaspoonfull a day right now, that's manageable for a few weeks.
Putting on oil pan gasket dry? Civicnewbie123 Honda Civic / Del Sol (1992 - 2000) 3 03-10-2015 01:38 PM
after replacing the oil pan gasket on my CRV 2000, it's still leaking CRVinsoCA Tech / Misc 9 09-10-2010 02:17 PM
oil pan swap any tips? Civic Racer X 7 Honda Civic / Del Sol (1992 - 2000) 2 05-23-2007 01:42 PM
Oil Pan Gasket??!?? AK94GSR Acura Integra 7 06-24-2003 02:24 PM
Oil pan gasket on 90 Accord jimby452 Honda Accord (1990 - 2002) 5 04-27-2003 11:11 AM
Tags
00, 2000, 98, change, civic, crankshaft, gasket, iol, oem, oil, oilpan, pan, replace, replacement, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
