how do you know if you have a bad wheel bearing? - Honda-Tech
Old 07-29-2010, 06:16 AM   #1
JDMcivic801's Avatar
Default how do you know if you have a bad wheel bearing?
i have a ej1 and when i drive it, it makes a weird thumping/vibrating sound. could anyone tell me if this is my wheel bearing? thanks in adavance
JDMcivic801 is offline   Reply With Quote
Old 07-29-2010, 06:23 AM   #2
fv8s's Avatar
Default Re: how do you know if you have a bad wheel bearing?
a wheel bearing sounds like a humming/ vibrating sound so that can possibly be it. if you had a video or something to reference we could help more
fv8s is offline   Reply With Quote
Old 07-29-2010, 06:49 AM   #3
doneking's Avatar
Check your tires on the side that it sounds like it's coming from. inspect them for separated tread, thrown weights, and bulges in the sidewalls or tread area.
Usually if there is thumping and vibration the cause can be.
* Tires out of balance (Thrown weight, etc.)
* Tires are unevenly wore (Not rotated regularly.)
* Out of alignment
I've just recently acquired a '99 Civic and I'm going through it getting things in order. Mine sounds like I'm rollin' on Buckshot Mudders. From the wear on my tires, I believe it is improper inflation and rotation and my tires are roaring.
DK
doneking is offline   Reply With Quote
Old 07-29-2010, 06:52 AM   #4
BlueIntegraBoy's Avatar
You'll get a humming sound. Jack up the car and if you can wiggle your tire, your bearings are bad.
BlueIntegraBoy is offline   Reply With Quote
Old 07-29-2010, 06:55 AM   #5
It's often described as a groaning or growling sound that gets louder with higher speed.
Former User is offline   Reply With Quote
Old 07-30-2010, 10:37 AM   #6
thanks guys ill check these all out
Old 07-30-2010, 11:04 AM   #7
HT Order of Merit
JDM_Ej's Avatar
They are pretty common to go. I could tell mine were because the front wheel(s) would shake at highway speeds.... badly lol.
JDM_Ej is offline   Reply With Quote
Old 07-30-2010, 11:56 AM   #8
also, when the car is jacked up, you can turn the tire and if the bearing is fairly bad, you will hear it making a grinding sound...
brett304 is offline   Reply With Quote
Wheel bearing problems thunderboy Acura Integra 8 03-20-2009 01:15 PM
wheel bearings or ball bearings??? spyderazn Honda Accord (1990 - 2002) 2 03-09-2008 06:28 PM
change wheel bearing Shay91Racer Honda Accord (1990 - 2002) 1 04-25-2007 08:29 PM
Anyone buy a OEM front wheel bearing lately? Tyson Honda CRX / EF Civic (1988 - 1991) 25 10-05-2005 06:12 AM
whats the deal with wheel bearings? rioninja Tech / Misc 3 08-21-2001 08:53 AM
Tags
audio, auto, automobil, bad, bearing, check, front, grinding, honda, pilot, rear, replace, rotation, sound, tire, troubleshoot, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
