How do u get the check engine light off?
Old 07-09-2003, 09:46 PM
awalk2005's Avatar
Default How do u get the check engine light off?
I did some work on the engine and the MAP sensor wasnt all the way plugged in. I plugged it in and the check engine light wont go off. How do u shut it off?
Old 07-09-2003, 09:49 PM
Eg6LazyPt's Avatar
Default Re: How do u get the check engine light off? (awalk2005)
disconect your positive battery terminal for 5-10 min then reconect it. clear it all up if thats your problem you'll have to reset all your radio stations though. thats the only downside. so remember them before you do it.
Old 07-09-2003, 09:53 PM
DubbleD's Avatar
Default Re: How do u get the check engine light off? (Eg6LazyPt)
or negative
Old 07-09-2003, 09:59 PM
milo's Avatar
Default Re: How do u get the check engine light off? (DubbleD)
or the backup 7.5 fuse for 10 seconds
Old 07-09-2003, 10:35 PM
RICE POLICE SIP's Avatar
Default Re: How do u get the check engine light off? (milo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milo &raquo;</TD></TR><TR><TD CLASS="quote">or the backup 7.5 fuse for 10 seconds</TD></TR></TABLE>
Yeah all you have to do is pull the fuse under the hood right next to the batt. (7.5) fuse for 10-15 sec..... and it should go away....
Old 07-09-2003, 11:45 PM
built562's Avatar
Default Re: How do u get the check engine light off? (92boostn'hatch)
or use a diagnostic scanner. you wont lose your radio stations or clock time either. its easy if you own one (or know someone who does)
edit: sorry, only for obdII cars
Old 07-10-2003, 12:18 AM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Strangely enough, I turn my car off/on and the check engine light is no more.
Cdeese910
10-25-2012 07:56 AM
sickofitall1113
08-20-2005 10:56 AM
10KrpmS2K
Honda S2000
08-11-2005 07:36 PM
slosol
09-20-2004 11:28 AM
Quick Reply: How do u get the check engine light off?
