how to do a sunroof over haul on a 92-95 civic eg
honda-tech people i know people are trying to find out how to remove the sunroofs because it stop working but when it time to do a change over you cant find no info on the overhaul and pictures. well i did mines today as of 7-8-11 because mines did stop working and i could not find no info before tearing things down and breaking something well here goes my write up with pictures enjoy guys hope this help people out before removing things bad and good comments are welcome.
step one you need tools
flat head screw driver
needle nose pliers
8mm socket
10mm socket
17mm socket
3/4 extension
turtle wax and beach cleaner if you really want to clean the plastic and everything to look good
step 2 tearing things down
the oh **** hanger
if you have a Canada model like me you take this down
visors
remove the light
8mm bolts
clothes hanger
removing the plastic sides above doors
removing the weather hard rubber from frame take off completely
take out diver seat belt 17mm
plastic off
remove the plastic stubs with philps head that holds the roof which they dont lol
remove rear stubs in the back with needle nose
removing pass rubber strip
remove hard rubber around the sun roof easy pull off
now roof should be hanging by removing the plastic around the car so carefully remove it with out bending it or it will look ugly lol
remember when removing the 17mm bolts for the seat belts it gives you play for the rear plastic to pop off not remove fully but to pop off the top and slide the panel
step 3 sunroof time take down
remove water drains theres 4 hoses
unplug power clips
10mm bolts 2 front 2 rear 2 pass 2 driver
and it drops make sure you have a extra person it would be easy when it drops and to put back up when to put back up you do it the same way you took it down by putting it back up
time took about a hr and a half with careful
hope it came out perfect enjoy
needle nose pliers
8mm socket
10mm socket
17mm socket
3/4 extension
the oh **** hanger
visors
remove the light
8mm bolts
clothes hanger
plastic off
unplug power clips
Re: how to do a sunroof over haul on a 92-95 civic eg
That looks easier than I was imagining, did you take pictures of disassembling the actual sunroof, cleaning the old grease out, etc?
Guess I have the motivation to tear mine apart tomorrow and find out why it doesn't work without physical help.
thanks man honda tech needed it because alot of people are looking for this and it was simple i woke up i am like hondatech needs a write up no one has it
Before ripping your sunroof out, try assisting it on it's way up. Just push the back edge up a little as you hit the button.
After removing the sunroof, what is your plan? Replace the motor, clean it all, scoop some new white grease in and hope it helps it? Weld a patch panel in? Aftermarket sunroof?
Hi,
My Civic is Ferio Ek3 1997 without Sunroof . Can I install the Sunroof without cutting and welding the roof?
Please help
Regards
Leo
Please help
Regards
Leo
Blacknight117
04-05-2012 06:41 AM
fms1day
59
06-19-2011 08:48 PM
Grocery Getter
10-07-2003 11:41 AM
