how do i replace shifter bushings ?
Old 11-07-2010, 02:49 PM
FTNW's Avatar
Default how do i replace shifter bushings ?
can anyone direct me to a how to ?
or is this something a shop should do ?
FTNW is offline
Old 11-07-2010, 02:55 PM
FTNW's Avatar
Default Re: how do i replace shifter bushings ?
:l
FTNW is offline
Old 11-07-2010, 03:08 PM
Crazy Honda Guy
Deetz's Avatar
Easy! the front shift rod, you remove one bolt, the rear, you remove two bolts, takes 15 mins
Deetz is offline
Old 11-07-2010, 04:24 PM
EJeff8's Avatar
The back one might make you cry though. It's one of the bitchiest things I've had to do. But a simple install nonetheless.
EJeff8 is offline
Old 11-07-2010, 06:06 PM
Ek Forever y0!
Libertariat's Avatar
It's very easy. Just get the bushings and some tools and take a look under your car. It's about as straightforward as an oil change.
Libertariat is offline
Old 06-20-2016, 10:36 AM
Stevieh62000's Avatar
Does that bottom 'T' shaped bit at the front just pull out? I was told that removing the gear linkage was one of the worst jobs to do on a honda due to the so called 'bitch' pin?
Stevieh62000 is offline
Old 06-20-2016, 11:15 AM
88CRX_SiR's Avatar
You don't have to pull the bitch pin to replace the bushings. It's just one bolt on the bottom of the transmission and two bolts under the shifter. Super easy to do, takes about 10 minutes.
88CRX_SiR is offline
Old 06-20-2016, 11:52 AM
eh2_Trav's Avatar
Its easy if you have the right tools. A punch and a hammer and its not too much of a bitch. Only little girls cry about the "bitch pin" and if they seriously think that's one of the hardest things to do on a Honda then they should stop while theyre ahead
eh2_Trav is offline
Old 06-20-2016, 02:07 PM
but just to be clear. You do need to remove the bitch pin to remove the full assembly? But you can replace the bushes while its still connected to the car right?
Old 06-20-2016, 04:10 PM
RodWolf19's Avatar
You can change the bushings with the assembly still on the car. No need to remove the pin.
RodWolf19 is offline
Old 06-21-2016, 07:41 AM
Premium Member
94 Civic Si's Avatar
How to make it stop rattling? Drives me crazy... Seems to be in the pin that joins linkage at the shifter.
Any ideal places to shorten the shift linkage after a B series swap into an EG?
94 Civic Si is offline
Old 06-22-2016, 09:51 AM
eh2_Trav's Avatar
you should start your own thread with this question, but be a little more specific and if possible post some pictures. I once bought a Honda from someone and they replaced the shifting linkage pin with a bolt and a nut. It sucked *** and had so much extra play. talked him down 800 bones for a 3.50 part
eh2_Trav is offline
Old 06-22-2016, 07:04 PM
Former User's Avatar
Former User is offline
92LsTegra
06-25-2004 11:29 AM
-faded-
06-07-2004 04:56 AM
92CIVICCX
01-20-2003 11:10 AM
Chairman Kaga
10-08-2001 05:46 AM
TypeR892
09-17-2001 02:43 PM
Quick Reply: how do i replace shifter bushings ?
