How do I access rear sunroof drainage holes? - Honda-Tech
Old 12-12-2008, 12:46 PM   #1
florida's Avatar
Default How do I access rear sunroof drainage holes?
Does anyone know how to clean out the rear sunroof drains? I cleaned out the front ones with a piece of acrylic tubing and an air pump, but cannot even find, let alone get to the rear drains. The car is basically the same as a 99 Civic. Thanks.
florida is offline   Reply With Quote
Old 12-12-2008, 12:53 PM   #2
instructor74's Avatar
the rear ones exit in the rear wheel well. I know on the 92-95 I used the tilt function to get to the rear channel drain holes. Be careful when using compressed air to clean out the lines I have seen it force the drain lines out of the rubber coupler where it exits through the body then the water drains inside the car
instructor74 is offline   Reply With Quote
Old 12-12-2008, 04:55 PM   #3
freakasis's Avatar
Quote:
you might have to pull the headliner, and yes compressed air can def blow the tube off because its held on with what is basically a metal zip tie.
freakasis is offline   Reply With Quote
Old 12-12-2008, 11:53 PM   #4
H-T White Ops
NOFX's Avatar
For 6th gens the moonroof assembly extends all the way to the back of the roof.
Removing the headliner won't do much, but removing the sunshade and glass (which lift through the top) might help at least with visibility. It's still a good foot or so back from the hole in the roof / moonroof assembly though.
You said the car you're talking about it "basically the same as a 99 Civic", so since I'm not really sure what it is, it could be very different.
The easiest way to access the moonroof tubes for the rear will probably be to drop the headliner and disconnect the tubes from the assembly. They are difficult to disconnect. I had to cut the front ones the last time I removed a moonroof assembly on a 6th gen.
NOFX is offline   Reply With Quote
Old 12-13-2008, 12:26 AM   #5
florida's Avatar
Quote:
My car is an Acura EL, the roof is the same as a 6th gen Civic. Thanks for the responses. I'm wondering why Honda made it so hard to clean the drains out.
Old 12-13-2008, 12:55 AM   #6
H-T White Ops
NOFX's Avatar
Quote:
Okay, the sedans have a shorter roofline than the coupes. I've only worked on coupes, but it should be close to the same.
I figure cleaning drain tubes isn't a normal thing to need to do, so that's why. It's not that bad.
Sunroof drain tubes - 1991 EF hatch bergercurtis Honda CRX / EF Civic (1988 - 1991) 6 01-07-2016 12:54 AM
sunroof drains civic meeka Honda Civic / Del Sol (1992 - 2000) 1 12-28-2012 08:57 AM
EF Hatch sunroof rear drain plug clean out sharmon Honda CRX / EF Civic (1988 - 1991) 11 12-16-2010 04:33 PM
sunroof drain tubes? Rear floor wet during rain. serious Honda Civic / Del Sol (1992 - 2000) 3 10-14-2005 03:02 PM
water in tire well johnzm Honda CRX / EF Civic (1988 - 1991) 8 10-30-2002 01:02 PM
Tags
1992, 2004, 9295, accord, civic, drain, drains, exit, hole, honda, lifter, moonroof, rear, sunroof, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
