How to check whether i have ABS or not?
Old 08-02-2009, 12:41 PM
OverBoostDemon's Avatar
Default How to check whether i have ABS or not?
Hey guys,
I am getting some new brake rotors and pads for my 94 civic hatch Si, how do I know if my car has ABS or not? Sorry if its a stupid question. Thanks for your reply.
Old 08-02-2009, 12:46 PM
Skip01's Avatar
Default Re: How to check whether i have ABS or not?
Do you have rear discs?
Do you have a big box thing with a bunch of brake lines going to it under the hood?
I think the only one that came with ABS is a 2dr EX....could be wrong though
Old 08-02-2009, 01:05 PM
Unseen Racer's Avatar
pretty much what he said.
check to see if you see the ABS pump under the hood.
you should see a bunch of brake lines coming from it.
and no. not the brake master cylinder
Old 08-02-2009, 01:12 PM
Scott.'s Avatar
slam on your brakes
if they lock up, then no
lolololol
Resident Gearhead
BryanM.'s Avatar
Look for the ABS pump/lines (circled in green in the pic).
This is an Integra but the Civic is pretty much the same.
Old 08-02-2009, 01:27 PM
Christopherian1982's Avatar
All you gotta check is your dash. If you see ABS lit up then you have ABS....
Old 08-02-2009, 01:29 PM
Freight Dawg's Avatar
If you hear tires screeching when you brake pretty hard, chances are you might not have ABS...
Old 08-02-2009, 01:40 PM
Ok I do have disc brakes in the rear here are some pics of my interior that may look like something like an ABS module. What do you guys think??
Old 08-02-2009, 01:42 PM
When does this light actually light up? When I start the engine? I will check that thanks man!
Old 08-02-2009, 01:51 PM
if you do not see the ABS pump, then you do not have ABS.
from the pictures, that just look like regular brake lines coming the your prop valve
Old 08-02-2009, 01:59 PM
bsmith100's Avatar
Originally Posted by skittle_107
slam on your brakes
That is what I was going to say!
Seriously though, you can look for the ABS pump.
Old 08-02-2009, 02:28 PM
EG8R's Avatar
You have ABS. That is the pump not the prop valve. Orange connectors also mean you have ABS.
Old 08-02-2009, 02:55 PM
Resident Gearhead
BryanM.'s Avatar
Old 08-02-2009, 10:33 PM
Originally Posted by OverBoostDemon
did not see the entire pic since it is too large and i did not feel like scrolling to the side
but yes. that is an ABS pump so you have ABS
now call your insurance company and have them give you a discount for ABS.
thats if your insurance gives out discounts for having ABS
Old 08-02-2009, 11:53 PM
MilanoEj1's Avatar
Another way to check is to see if your axles have a gear set of teeth around them
Old 08-03-2009, 05:57 AM
g230sport's Avatar
easiest way would be to turn the key on to the acc position. if theres an abs light that comes on, you have abs...
Old 08-03-2009, 09:29 AM
Jimster480's Avatar
ya i am pretty sure that Si's have ABS.
Old 08-03-2009, 09:37 AM
Linked's Avatar
i have a '94 usdm EX and my ABS light doesnt come on when i start my car.
the oil, battery, check engine, and seat belt (when its not strapped in) only come on.
but ALL '94 civic EX's were suppose to have ABS
or my bulb could have blew out
Old 08-03-2009, 09:50 AM
well not ALL of them came with ABS.
only a few selected ones came with it
Old 08-03-2009, 12:14 PM
Hey you guys RULE! Thanks for that info. I went ahead and ordered my ABS rotors n brake pads!!
Old 08-03-2009, 12:24 PM
Linked's Avatar
ohhhh. but mine DOES have abs. i have the pump in there, just checked lol
but i have the yellow ABS indicator on the dash, it just doesnt light up when i start my car
Old 08-03-2009, 12:25 PM
Jimster480's Avatar
it would be sick if my fkn 97 EX came with ABS. I know some of them did but mine didnt :/
Old 11-02-2010, 05:40 PM
blk_dc's Avatar
I know this thread is old and I came across it to help me with abs, but what is the black box on the drivers side above the power-steering reservoir with a green wire coming out of it??... is that part of abs..
Thanks!
Old 11-02-2010, 05:44 PM
fv8s's Avatar
its the cruise control
sensei1100
06-11-2010 04:27 AM
90teg
05-02-2006 08:20 PM
dclute
09-27-2004 03:17 PM
ajchen
18
10-03-2001 10:42 PM
Quick Reply: How to check whether i have ABS or not?
