how can you tell if a fuel pump is going bad? 93 civic-b16 - Honda-Tech
Old 07-21-2004, 07:15 PM   #1
DjN3M3S1S's Avatar
Default how can you tell if a fuel pump is going bad? 93 civic-b16
well ive been having problems starting my car lately. sometimes i dont hear my fuel pump ingage when i turn the key half ways, and doesnt start. sometimes i do hear it, it starts, and then dies right away. its been going on like this for awhile, just started getting worse lately.
and if i do need a new one, do i buy one to match b16 or the 93 civic. cuz i looked online and its seems to be different parts.
if anyone could help that would be great.
thanks
DjN3M3S1S is offline   Reply With Quote
Old 07-21-2004, 07:46 PM   #2
bens_redeg's Avatar
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (DjN3M3SiS)
it could be your main relay;that controls your fuel pump but if you find out that it is your fuel pump get one for the car not for the motor are you throwing any codes
bens_redeg is offline   Reply With Quote
Old 07-21-2004, 07:51 PM   #3
VvPeachyvV's Avatar
i'm have the exact same problem with my d series motor, i haven't got the chance to see what it is tho, but i thought about it being the main relay, i'm not quite sure how to check that though =/
VvPeachyvV is offline   Reply With Quote
Old 07-21-2004, 08:00 PM   #4
Ricey McRicerton's Avatar
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (VvPeachyvV)
Take a look at the FAQ thread. There is a how to on checking/fixing it.
Ricey McRicerton is offline   Reply With Quote
Old 07-21-2004, 09:51 PM   #5
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (bens_redeg)
Quote:
the civic is putting less lph (liters per hour). i rather get the one for the motor and not the car.
i have gsr fuel pump in my civic for the b18c.
wizzards581 is offline   Reply With Quote
Old 07-21-2004, 10:08 PM   #6
Spence's Avatar
take the fuel pump out hook up a couple of wires and test it on the battery and see if the motor is spinning !!!!!!!!!!!! Thats how i did it and i think thats how the helms tell you to do it
Spence is offline   Reply With Quote
Old 07-21-2004, 10:11 PM   #7
DjN3M3S1S's Avatar
Default Re: how can you tell if a fuel pump is going bad? 93 civic-b16 (Ricey McRicerton)
where do i find
"Take a look at the FAQ thread. There is a how to on checking/fixing it. "
Old 07-22-2004, 02:57 AM   #8
LSpimpTEC's Avatar
same thing happened to me...main relay....i have an extra one if you want to buy it. pm me
LSpimpTEC is offline   Reply With Quote
Old 07-22-2004, 04:22 AM   #9
Silent_Bob's Avatar
If the main relay doesn't klick, open the door and hit the left side of the dashboard, works everytime, you can also keep the starter going while hitting the side of the dashboard and the car will start. If the car has been in the sun for a while, thats enough to make the realy not click, or if the car has been used for like 10minutes.
Silent_Bob is offline   Reply With Quote
Old 07-22-2004, 04:12 PM   #10
DjN3M3S1S's Avatar
Default Re: (Silent_Bob)
wow. never thought of hitting the side of the dash. im thinkin it may be the main relay, because its starts every morning, during the day when i drive it in this AZ heat is when i have the most problems. also when it sits in the sun all day, it wont klick until the its starts cooling off. and at night, it always starts..
think is could be the main relay?
if soo how much do they run
Clicking noise from main relay / fuse box area? gnozahs Honda Civic / Del Sol (1992 - 2000) 3 01-20-2016 10:01 PM
Fuel Pump/Relay Question??? GsrTeg95 Acura Integra 1 04-09-2011 02:40 PM
Stalling & starting problems: Ignition? Relay? Fuel pump? Dec0y Honda Civic / Del Sol (1992 - 2000) 8 11-16-2010 04:23 PM
fuel problem? sputtering? pjr710 Honda Civic / Del Sol (1992 - 2000) 0 03-22-2010 09:15 AM
D15b, starts and fires up but will not stay idle atarigamer01 Honda Civic / Del Sol (1992 - 2000) 13 06-24-2009 11:25 AM
Tags
2002, 93, 95, 97, b16, bad, check, civic, del, fuel, honda, integra, pump, pumps, sol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
