how to bleed a clutch?
Re: how to bleed a clutch? (slow_redcivic)
Attach a hose to the bleeder screw and suspend the hose in a container of brake fluid.
Make sure there is an adequate supply of fluid at the clutch master cylinder, break the bleeder bolt loose, then slowly pump the clutch pedal until no more bubbles appear at the bleeder hose. Retighten the bleeder bolt.
Refill the clutch master cylinder with fluid as needed and when done.
hondaless
04-02-2009 08:58 AM
afropuffs808
05-02-2008 06:17 AM
