How to adjust parking brake?
Old 09-02-2009, 08:53 AM
2007430's Avatar
Default How to adjust parking brake?
Hi, I have a 97 Civic LX 5 Speed.
My question is, the 'button' that you press in when lifting up to disengage the parking brake has gone deeper and deeper into the lever to the point where I have to use my index finger to push it in. How can I readjust it to make it stick out further?
Old 09-02-2009, 09:06 AM
Former User's Avatar
Default Re: How to adjust parking brake?
Start by checking whether the rear pads are worn and need replacing or whether the self adjust mechanism (clevis A,B and adjuster bolt) is seized up.
Old 09-02-2009, 09:12 AM
2007430's Avatar
Thanks for the reply, I actually changed the rear brakes about 2-3 months ago, everything seemed fine.
Old 09-02-2009, 09:37 AM
Does the self adjust mechanism in both wheels turn freely?
Old 09-02-2009, 09:41 AM
2007430's Avatar
They did at the time I did it.
Will turning the nut that is on the cable in the center console do anything to solve this problem?
Old 09-02-2009, 06:22 PM
Old 09-03-2009, 06:10 AM
Kista20's Avatar
I replaced the shoes on the back of my hx couple months ago and had to turn the adjuster nut under the console to adjust the brakes... never heard of the e-brake button messing up but pull the console off and check everything out, sounds like something has failed inside of it.
Old 09-03-2009, 07:57 AM
2007430's Avatar
Originally Posted by RonJ@HT
Thanks, I'll see about trying this over the weekend when I have some time. I'll let you know how it goes.
Yeah I am worried that it could be something internal.
Just out of curiosity because I would like to look at it to at least get a better idea of how all the parts work, can someone please tell me how to remove the actually parking brake lever?
Old 09-03-2009, 06:10 PM
EKCoupeKid98's Avatar
Is it necessary to jack up the car? Can you just tighten it without doing that (skipping step 1 and 2). I knew my ebrake had gotten a lot of slack, but I counted 15 clicks.. 6-9 is correct? Haha..oops!
Old 09-04-2009, 11:11 AM
RonJ@HT? Help! Can I just adjust the adjusting nuts without it being jacked up and messing with the calipers?
Old 09-04-2009, 11:16 AM
worlds-slowest-EG's Avatar
Just park somewhere flat, put it in park or 1st gear, leave the brake released and tighten the nut. simple as that!
Old 09-04-2009, 11:18 AM
Well what's all this about having to make sure that the caliper is touching and **** like that? And just adjust it till it tightens in 6-9 clicks?
Old 09-04-2009, 11:22 AM
You need the rear end raised so that, after adjusting the parking brake cable, you are able to verify that the rear brakes don't drag when the parking brake is fully released.
Old 09-04-2009, 11:23 AM
Don't go all crazy tightening it. you can check your progress easily by just pulling up on the brake every turn or so
Gotcha, thanks!
Old 02-01-2011, 11:21 AM
scottmotron's Avatar
I know this is an old thread, but I just found a solution to this that I thought I'd share. If the e-brake button is hiding inside the e-brake lever, it could because the plastic handle has crept up on the metal lever housing. Sounds like this is a fairly common occurrence with these cars.
To fix, simply get a rubber mallet or something and tap the plastic handle back down onto the lever. No brake work required, and you don't even have to remove the console. I hope this helps someone out there. I personally am stoked i get to do bootleg turns again on those snowy days! yee-haw.
--scotto
Old 02-09-2011, 02:50 PM
ddaniels750's Avatar
Gotta have that e-brake for snowy days!!
Old 02-09-2011, 03:09 PM
Pancho2193's Avatar
Remove the Handle, and there will be a spring (There was one on mine) its probably stuck, just pull that out! Oh and its the outer casing outside the button that is being pushed forward. Try pulling that back
Old 02-09-2011, 03:25 PM
alphalanos's Avatar
--scotto
This happened to mine. I just grabbed onto the e brake handle and pulled backwards(with a good amount of force) and it slid right back into place. I also thought something was wrong until I just started messing with it.
Treyschls
Suspension & Brakes
10-02-2015 02:16 AM
civicekgsr99
Suspension & Brakes
11-07-2008 01:46 PM
espm1000
09-14-2006 09:47 AM
PreludePhill
05-05-2006 07:22 AM
lilman4o8
06-09-2005 07:33 AM
Quick Reply: How to adjust parking brake?
