How to adjust the a/c belt tension - Honda-Tech
Old 06-24-2007, 09:09 PM   #1
joeEK00EX's Avatar
Default How to adjust the a/c belt tension
Hey well I have a problem with my D16Y8 it makes a noise when I turn on the A/C in my 00 EK EX so I'm guessing is my ac belt how do I tighten it up can you guys help? TNX
joeEK00EX is offline   Reply With Quote
Old 06-24-2007, 09:49 PM   #2
Moderator
tech8's Avatar
Default Re: How to adjust the a/c belt tension (joeEK00EX)
The noise you are hearing is not a growl, right? If it is, it may be a bad A/C Idler Pulley Bearing. Here is a TSB:
http://www.tegger.com/hondafaq...e.pdf
But, to answer your question on how to adjust the A/C belt tension:
(Use the image in the TSB as a guide, so you know which is the pulley center nut, and which is the adjusting bolt.)
1. Loosen the center nut on the pulley (Loosen, don't remove).
2. Turn the adjusting bolt to get proper tension.
3. Re-tighten the center nut on the pulley.
tech8 is offline   Reply With Quote
Old 06-25-2007, 12:23 AM   #3
joeEK00EX's Avatar
Default Re: How to adjust the a/c belt tension (tech8)
Hey thanks bro preciate noise is gone.
Honda Accord 2000 EX Belt Question...How Many? aznromeo4u Honda Accord (1990 - 2002) 4 02-18-2015 08:51 PM
which air conditioning belts for b-series swap into ek? 1zach4 Honda Civic / Del Sol (1992 - 2000) 5 07-25-2010 04:53 PM
Alternator belt change question dotay Honda Civic / Del Sol (1992 - 2000) 4 12-30-2006 02:35 PM
changing engine belts? hott-nix Acura Integra 3 02-05-2005 01:07 PM
A/C belt installation on 96 Civic sjheise Honda Prelude 1 11-26-2004 08:50 PM
Tags
2000, 2001, ac, adjust, adjusting, belt, belts, civic, crx, dx, honda, tension, tensioner, tighten, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
