Horn not working, only "click" sound - 98 Civic
Old 04-11-2010, 01:35 PM
EKCoupeKid98's Avatar
Default Horn not working, only "click" sound - 98 Civic
Couldn't find a previous thread, sorry if there is one.
1998 Honda Civic EX. Had an auto shop replace my horn when someone hit my car and I was taking it in for work anyways. I got an aftermarket horn (can't remember brand) from Auto Zone. About a year later, whenever I press the horn, it just makes a click sound. If I press the horn about 30-40 times, it will finally start working, and then be good for the remainder of the trip. After I drive it the next day, the horn will go back to it not working and then working after I push it 30-40 times. So.....
I would like to see if anyone could help me out. The horn works after a while, so I don't think it's the horn. Maybe it's a fuse/relay/grounding? Does anyone know what I should check?
Also, it's a bit of a wimpy horn, can anyone recommend a good one to buy? Are there two horns for a Civic? One high and one low? Do I need to buy two?
If anyone can help, it'd be greatly appreciated. Thanks for looking.
Old 04-11-2010, 03:13 PM
Blahblah718293's Avatar
Default Re: Horn not working, only "click" sound - 98 Civic
the click you hear under the dash is the relay clicking, which means at least half of the wiring is good, including the switch. its propably a bad horn, maybe a bad internal connection, or check the wires going to the horn where it got smashed.
Old 04-11-2010, 03:15 PM
Smashed? Can you recommend a good horn? I'm going to change it no matter what, I just want it to work for now while I search for a new one and for it to be working when I replace it.
Old 04-11-2010, 03:32 PM
cityslicker1606's Avatar
get a train horn
Old 04-11-2010, 03:48 PM
I've heard Hella Horns worked well.. Anyone have these? Are there two horns or just one?
Old 04-11-2010, 03:54 PM
i usually just get the cheapo autozone horn, they have different tones, i usually go with the deepest one. i think theres just one horn.
Old 04-11-2010, 03:58 PM
Can anyone confirm this?
Also, it looks like Hella Horns are really annoying, I just want a louder stock-sounding horn that doesn't sound as dinky as the OEM Civic one. Maybe an Accord or newer Civic has a better sounding one? Anyone know something about Fiamm Horns?
Old 04-11-2010, 04:10 PM
like i said, an autozone horn will work fine, and they come in different tones, deeper = less dinky.
Old 04-11-2010, 04:12 PM
I understand the deeper part, but my horn I bought about a year ago was $10ish and it may be broken now.... I'm not sure, so I want a reliable one.
Old 04-12-2010, 03:58 PM
Anymore help?
Old 04-12-2010, 04:11 PM
jdm_ekcivic's Avatar
I second the train horns.
Old 04-12-2010, 04:26 PM
Master Detailer
98civdx's Avatar
You cant expect a $10 horn to last a long time, go buy a new one,
my dad wants to put a trian horn in mine.
taguchi08
12-09-2008 08:20 AM
zenon8890
10
11-16-2008 04:42 PM
tei344
11-09-2007 05:51 AM
Redemption
06-24-2007 03:18 PM
detaude
07-19-2004 02:48 PM
Quick Reply: Horn not working, only "click" sound - 98 Civic
