Which hood pins work the best?
Old 07-18-2005, 07:46 AM
rasinhell's Avatar
Default Which hood pins work the best?
Hey guys. I know that there are a lot of thieves that pull the hood release cable and then get into the bay and cut the alarm. So I guess as a theft deterrent I would like to know more about hood pins.
- Are they easily picked?
- When companies sell hood pins, do they use the same keys for all the hoods or are they all different.
- Is there any hood pin that doesn't stick out so much?
Well I guess the main question would be- when it comes to someone trying to jack your car, will the hood pins act as a good deterrent or is it a waste of time, hood, and money?
Old 07-18-2005, 07:54 AM
Ricey McRicerton's Avatar
Default Re: Which hood pins work the best? (Plugg'd)
You need hood locks brother, not hood pins. You can open just about any type of hood pins within seconds, even Dzus fastners.
Old 07-18-2005, 08:26 AM
GetawayInMoscow's Avatar
Default Re: Which hood pins work the best? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">You need hood locks brother, not hood pins. You can open just about any type of hood pins within seconds, even Dzus fastners.</TD></TR></TABLE>
I thought I read in another thread that hood locks arent secure enough and a good set of hood pins was the way to go?
Old 07-18-2005, 08:30 AM
Default Re: Which hood pins work the best? (GetawayInMoscow)
That's not what I understand, but I could be wrong. I have very limited experience with any of them.
Old 07-18-2005, 08:33 AM
cute little bastard
SkoundrelUSA's Avatar
I heard that those hood locks (circle style key) can be picked with a Bic pen...
I've seen people use the hood PINS itself and just lock them with Master key locks.
Old 07-18-2005, 08:37 AM
Default Re: Which hood pins work the best? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I heard that those hood locks (circle style key) can be picked with a Bic pen...
I've seen people use the hood PINS itself and just lock them with Master key locks.</TD></TR></TABLE>
Eh, you can cut those with a bolt cutter very easily. Are there no hood pins with a non-circular lock (more of a torx or wheel key type lock)?
Old 07-18-2005, 09:34 AM
rasinhell's Avatar
Sorry guys, I was under the impression that hood pins and locks were the same thing... So I guess now the question is, which is more secure?
Old 07-18-2005, 10:02 AM
suspendedHatch's Avatar
Move your hood cable from inside the fender to inside the engine bay, then wrap the latch mechanism with sheet metal. You should even move the hood release handle itself to slow them down even further.
I have a hood lock that I bought from the ricer section at pepboys. They're pretty cheap quality in that they will break if they're the only thing holding down your hood (I had a cf hood with no latch at one time). When it broke I bought another and the old key didn't fit it. They say they're unpickable, but like all things, I'm sure there's a way through it. If it slows them down and deters the amateur thieves then I'm happy. I have many layers of security behind it.
Old 07-18-2005, 10:57 AM
jmayhew's Avatar
Default Re: Which hood pins work the best? (suspendedHatch)
these are the only locking ones i know of...
you can get in metal or Carbon Fiber
for like $20 on ebay.
i just like them cause they are flush mounting compared to the other styles
Old 07-18-2005, 11:02 AM
Luserkid's Avatar
Default Re: Which hood pins work the best? (jmayhew)
Thats funny how they advertise those and then have the ITR with hood pins instead.
Anyway i had those types, gave me alot of problems and there easy to break. Best thing ive seen was hood pins with master locks. Dont forget not matter what you do a theif could always tow your car and have all the time in the world.
Old 07-18-2005, 11:11 AM
jmayhew's Avatar
Default Re: Which hood pins work the best? (Luserkid)
these are not locking but interesting design
Old 07-18-2005, 11:24 AM
avramzzz's Avatar
I have the CF look a like and got mine for 20 bucks from ebay. They work just fine, and they do lock down my CF hood hood. Email me if u want pics.
Old 07-18-2005, 11:37 AM
jdmsiR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmayhew &raquo;</TD></TR><TR><TD CLASS="quote">
garbage
well actually... they do serve their purpose, and i do like the aluminum version because its clean and flat...
but simply push down on the hood, and twist the actual lock.... voila, its off. once hit a huge dip in the road, jolted my hood, and one lock came off..
anybody have pix of the hood pins w/ master lock? sounds funky but its best than everything else here
Old 07-18-2005, 12:05 PM
eg4usdm's Avatar
okay well ive had those locking ones and they are only a pain the *** and they break
i just got the sparco hood pins and they work just fine and dandy
i got the new hondatuning magazine and the article deemed "compression check" they have an ek hatch and he has these
http://www.prostreetonline.com...39010/
they are moroso hood pins, ive heard goos stuff bout them.
Old 07-18-2005, 12:45 PM
.brad's Avatar
Default Re: Which hood pins work the best? (eg4usdm)
I have the Sparco hood pins with the OEM hood lock/latch.
Old 07-18-2005, 01:14 PM
Quad-Damag's Avatar
Default Re: Which hood pins work the best? (.brad)
i got these from summit a long time back
they work well
they are metel
Old 07-18-2005, 01:19 PM
EJ1 wilcox's Avatar
Default Re: Which hood pins work the best? (Quad-Damage)
I use Sparco hood pins...
They are cheap and effective. They are nothing fancy, they just hold the hood down. I like them because they are one piece, meaning, there is no part of the pin that can come off and get lost or stolen.
I don't like those CF hood locks because the "carbon fiber" looks really fake and cheap.
Old 07-18-2005, 01:27 PM
* B A N N E D *
Newark Built's Avatar
I bought the ones from HOODPINS.COM, and being a machinist they are pretty good quality .
I know some people would say you can still open the hood easily...but I mounted them so you do not see them at all...
Basically invert them...Mount the "stick" part to the underside of the hood, and the recieving portion mount inside the engine bay and run a few cables so you can release it from inside the car shhhhhhhhh
Old 07-18-2005, 01:39 PM
black cx's Avatar
Default Re: Which hood pins work the best? (Newark Built Kandy SiC-RX)
is the nrg hood locks garbage?
Old 07-18-2005, 02:26 PM
black cx's Avatar
bump
Old 07-18-2005, 02:52 PM
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default Re: Which hood pins work the best? (black cx)
the dzus fasteners are nice but finding a way to mount the tabs are hard
here's what it looks like
Unlike regular hood locks in which you mount the actual bolt to the holes on the rad supprt (EK) or headlight (EG), the dzus tabs woudl require being welded where you want to mount the fasteners unless you can fab a way of mounting it.
Old 07-18-2005, 08:29 PM
93civicsedan's Avatar
Default Re: Which hood pins work the best? (BrokeAssPinoy)
Ive heard that this lock by DEI is a good deterrent http://www.autotechs.com/items/item567.htm
Old 07-23-2005, 12:01 PM
Default Re: Which hood pins work the best? (93civicsedan)
Sparco doesn't stop someone from opening your hood. It doesn't sit flush either.
Your OEM hood latch doesn't stop someone from opening your hood, unless you reroute the cable and then hide the handle so they don't smash your window and pull it.
The DZUS look nice and flush, but can be turned with a screwdriver. Maybe use these to secure the hood, then use the Pepboys/ebay/summit hood lock to lock it down for you. And no they can't be picked with a bic pen, wrong diameter (and there are about four different diameters and key sets from what I've seen).
If you have the hood pins latched and you can still push the hood down, you need to tighten them or else it's going to bounce around when you're on the freeway. If they're tightened down properly I don't see how a thief could push the hood down even further. I've had hood locks installed in both a CF hood and a metal hood and you couldn't push it down further or somehow turn the inside of the locking mechanism.
I can't tell what that DEI thing is, but it's probably something similar to the OEM hood latch in function.
Add the hood pin switch to your alarm system.
All hood pins are an incredible pain in the *** to install and use. Too bad someone doesn't come out with something useful/reliable/secure.
Devo94ac
03-09-2006 05:47 AM
sleeperLS
08-25-2005 10:00 AM
DubyaAye
62
09-13-2004 08:22 PM
Soon_2b_evil
03-24-2004 03:20 PM
Quick Reply: Which hood pins work the best?
