Hood latch won't unlock???
Old 02-24-2009, 08:55 AM
mike03,95civic's Avatar
Default Hood latch won't unlock???
For some reason recently my hood latch will not unlock. It takes one person pulling the hood release cord a bunch of times, while another person pulls hard and wiggles the hood. From what I can see nothing is missing and everything is intact. Has anyone had this problem and fixed it? If not I guess I'll have to start searching junk yards. Thanks in advance for any help.
Old 02-24-2009, 03:03 PM
KuEy's Avatar
Default Re: Hood latch won't unlock???
there's a plastic deal that slides in place so that when you pull the release cord, it releases the latch. that plastic piece might of broke and it's sliding in place. get pics up of the latch.
Old 02-24-2009, 03:09 PM
ol Dusty's Avatar
prolly a streched cable but next time you open it try cleaning it up and then lubing it
Old 02-26-2009, 07:02 AM
Where is the plastic piece located? Is it near the hood latch or along the cord?
I did lub it up and it work for about 3 min. of poping and closing the hood but then it went back to not unlocking. And before I put on this lubricating grease I used compressed air to clean out any build up on the hood latch.
Old 02-26-2009, 08:51 AM
97TURBOHX's Avatar
I experienced this on my 97 Civic HX and the cable had stretched for whatever reason (probably popping the hood so many damn times ) You can take it off and find a place that makes clutch & throttle cables for motorcycles and they can shorten it up a little bit. (that is if you have a barrel end that fits into the plastic piece @ the hood latch
Old 02-26-2009, 10:11 AM
goldrushsi's Avatar
If you get down and look behind of the black plastic hood release, you'll see the cable. You can tell if it's stretched because you will see it being slack. Temporarily, you could always use a pair of pliers to pull on the cable.
Old 02-27-2009, 06:38 AM
KuEy, you were right. The plastic piece that is attached to the cord is still attached but what happened was it slide out from the sideways U that it mounts to. So when I put it back to where it should be it has tension and when I pull the hood release it pops open with no problems. Thanks for the help everyone!
Anybody know how I can keep that piece from sliding out again? It looks like it is too tight of an area to weld the metal U to make it closed.
mbdm
01-20-2011 02:32 PM
andlude
07-09-2008 10:06 AM
Nocturnal
46
10-02-2005 05:14 AM
blueaccord94
03-26-2005 07:53 PM
rustboy
02-16-2004 06:26 PM
Quick Reply: Hood latch won't unlock???
