Honda Civic EX Rear Seal Question 1999 - Honda-Tech
Old 11-03-2012, 03:23 PM   #1
Default Honda Civic EX Rear Seal Question 1999
I am in the process of changing the rear crank seal on my Civic. I also need to change the oil pan gasket and distributor o-ring. I have decided to remove the aluminum seal plate so I can install the seal easier. Is there a gasket that seals the plate to the block? Also, I have read in other posts that the VTEC solenoid seal can leak in this area. Where is this located? Are there any tricks I need to know? Thank in advance. This is a great DYI website.
Thom
drsab2000 is offline   Reply With Quote
Old 11-03-2012, 04:53 PM   #2
Technical Hero
HondaPartsHero's Avatar
Default Re: Honda Civic EX Rear Seal Question 1999
You'll have to remove the entire transmission to replace the rear main seal.
HondaPartsHero is offline   Reply With Quote
Old 11-03-2012, 05:42 PM   #3
I have removed the tranmisssion already. I have a lot of oil in the clutch housing. I'm trying to figure out what seals and gaskets I will need.
Old 11-03-2012, 06:15 PM   #4
Quote:
Is the leak engine oil from the rear main seal or MTF from the transmission input shaft seal?
Are you asking whether there's a gasket between the engine and clutch housing?
Former User is offline   Reply With Quote
Old 11-03-2012, 07:57 PM   #5
RonJ
The leak is from the engines rear main seal (crankshaft). The seal is pressed into an aluminum plate that is bolted to the engine. Is there a gasket between this plate and the engine or do I use hondabond? I haven't removed the pan yet. It's also leaking.
Old 11-03-2012, 08:19 PM   #6
The right side cover is sealed with Hondabond:
Old 11-03-2012, 08:30 PM   #7
DanCan'tSwim's Avatar
there is a gasket where the plate and the engine meet. I if I remember correctly the rear main seal came with it. it's really thin and looks feels like paper.
DanCan'tSwim is offline   Reply With Quote
Old 11-03-2012, 08:52 PM   #8
Quote:
It's called Hondabond.
Old 11-03-2012, 09:02 PM   #9
RonJ
Thanks! That's exactly what I was looking for. Like the previous poster indicated, some FelPro kits I have seen on eBay provide a paper gasket with the seal. Seemed confusing. Thanks again.
Thom
Old 11-03-2012, 09:05 PM   #10
My information is for the OEM right side cover.
F23 rear main seal plate- does that have a gasket? + are h22 sump gask. same as H22? Dxs Tech / Misc 2 03-24-2015 11:49 AM
'99 2.3L oil pump gasket tobytigger Honda Accord (1990 - 2002) 0 07-19-2012 05:22 PM
94-01 Rear main seal install help? zrs6v4 Acura Integra 2 10-14-2009 10:52 AM
Rear main seal?! hondahead' Honda Civic / Del Sol (1992 - 2000) 8 07-20-2009 07:57 PM
Need to know 91ef2 Honda CRX / EF Civic (1988 - 1991) 5 03-26-2009 12:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
