honda civic 95 radio no power 😠
So I have a after market radio and I was trying to find the aux connection and for some reason I lost power i checked all the wires and the fuses but I am not getting no power
Re: honda civic 95 radio no power 😠
can't tell which wire you are testing there should be 2 hot when the key is on.
I believe the Red is switched, on or off depending on key position
yellow is constant 12 v regardless of key on or off
So do you have battery voltage at pins 4 and 5?
If so, check the ground wire at pin 11. A circuit requires both power and ground. Either alone is useless.
I have the same problem I replaced both of the fuses 7.5 back up in engine bay and radio 15 in the dash and still no power to my radio
Factory or aftermarket radio?
Pull the radio. Check continuity from harness like photo from above.
check for fray wires.
Make sure radio wires are correctly connected to adapters and color matched.
kimocuda
Audio / Security / Video
11-28-2007 07:33 AM
Hatchback of Notre Dame
02-05-2006 10:52 AM
