High pitch noise coming from engine. - Honda-Tech
Old 06-17-2010, 05:24 PM   #1
JasonYo's Avatar
Icon3 High pitch noise coming from engine.
So when my engine is warm and only at idle it starts to make this high pitch whistling/squeaking noise. I know that it is not any of the belts or the intake. It is also not any of the vaccume hoses on the intake manifold.
Heres a video to see what it sounds like. You can hear it really well towards the end.
http://www.youtube.com/watch?v=VINMLaXpU4o
If anyone knows what it could be please help, it is the most annoying thing ever! And I cannot figure this out! Thanks.
JasonYo is offline   Reply With Quote
Old 06-17-2010, 05:47 PM   #2
_eg6_'s Avatar
Default Re: High pitch noise coming from engine.
man thats a tough one gl
_eg6_ is offline   Reply With Quote
Old 06-17-2010, 05:59 PM   #3
JasonYo's Avatar
Ya I know lol. thanks.
Old 06-17-2010, 07:57 PM   #4
Sounds like a bad pulley bearing. Use an inexpensive engine stethoscope to pinpoint the noise.
Former User is offline   Reply With Quote
Old 06-17-2010, 08:21 PM   #5
JasonYo's Avatar
Alright I'll try to check those out.
Old 06-17-2010, 08:24 PM   #6
b1u3_5i's Avatar
Also check your alternator. If you can, start eliminating a/c, altrernator, p/s belts one by one, and see if the sound goes away. I hope this helps.
b1u3_5i is offline   Reply With Quote
Old 06-17-2010, 08:36 PM   #7
JasonYo's Avatar
Well I don't have a/c, and I ran the engine with the alternator belt off so it's not that.
I might try disconnecting the p/s belt to see if its that.
Old 06-17-2010, 09:38 PM   #8
itsmejto's Avatar
cheap stethoscope = piece of hose.
itsmejto is offline   Reply With Quote
Old 06-18-2010, 08:28 AM   #9
JasonYo's Avatar
Hmm yes, good idea!
I'll try to pinpoint the noise first, but I did listen very carefully for a while the other day and it seems to be coming from the cam pulley area or just behind. The noise is clearly not from the p/s area.
Is it possible that the timing belt is to tight or something?
Or could the pulleys be making this noise?
Old 06-18-2010, 10:27 AM   #10
Try squeezing your pcv hose when it's making the noise.
Atomic1 is offline   Reply With Quote
Old 06-18-2010, 10:32 AM   #11
Hill4589's Avatar
Quote:
Agreed. And I wanted to compliment you on how clean the engine bay is!
Hill4589 is offline   Reply With Quote
Old 06-18-2010, 11:04 AM   #12
BrandonR's Avatar
Honestly, it sounds like air whistling as it goes through the IACV passages. If you notice it only whines when the IACV opens up. I had a 5.0 Mustang that did that, as well as many other 5.0's. Take off your IACV and sand the sharp edges down slightly.
BrandonR is offline   Reply With Quote
Old 06-18-2010, 11:12 AM   #13
blackKready's Avatar
yeah its definitely air. soon as you give it even the littlest throttle it goes away.
blackKready is offline   Reply With Quote
Old 06-18-2010, 02:32 PM   #14
JasonYo's Avatar
I'll check the IACV, I was told it was a air leak or something for sure.
Old 06-18-2010, 02:34 PM   #15
JasonYo's Avatar
Quote:
Thanks! I try to keep it as clean as possible.
Old 06-18-2010, 02:36 PM   #16
The locations of the sound and IACV aren't a good fit.
Old 06-18-2010, 02:49 PM   #17
JasonYo's Avatar
Yeah, well the sound is more towards the rear drivers side of the engine. It's not at all near the tb. So it's probably not that.
Old 06-18-2010, 02:53 PM   #18
Sounds like the alternator. As already mentioned, remove the alt belt to see if the sound goes away.
Old 06-18-2010, 10:27 PM   #19
JasonYo's Avatar
Yeah I did that and the sound didn't go away!
A lot of people have been telling me that it sounds like a air leak, not bad bearings. I don't know tho.
Old 06-19-2010, 06:40 AM   #20
JasonYo's Avatar
Someone said that it could be a intake valve leaking. Is this possible?
Old 06-19-2010, 07:05 AM   #21
Seriously, I paid only $4 for an engine stethoscope at Harbor Freight Tools.
Old 06-19-2010, 03:14 PM   #22
JasonYo's Avatar
Well I'll get one it's just that I work everyday except sunday and I can only work on my car at night. Stores are pretty much closed when I'm off.
I guess i'll just wait until then.
Old 07-15-2010, 03:13 PM   #23
JasonYo's Avatar
Any more Ideas as to what this might be?
Still haven't figured it out, and don't have the time to do anything big like take my engine apart. =/
Old 07-16-2010, 11:16 AM   #24
That's a clean *** engine bay
+1
Dymond is offline   Reply With Quote
Old 07-16-2010, 10:53 PM   #25
JasonYo's Avatar
Thanks!
'03 Accord EX Belt Noise? (With Video!) Ag3ntSm1th Honda Accord & Crosstour (2003 - Current) 9 12-31-2010 01:55 PM
strange high pitch noise from air filter unclematt Acura Integra 3 06-01-2008 09:15 PM
High pitch chirps from exhaust...? Hatchtrap Honda Civic / Del Sol (1992 - 2000) 14 12-06-2004 08:49 AM
high pitch noise??? troubleshoot???? 95dc2 Acura Integra Type-R 0 09-12-2004 04:40 PM
high pitch noises coming from engine bay pennies_hatchie Acura Integra 2 04-02-2004 10:03 PM
Tags
bad, cheap, engine, high, honda, idle, intake, makes, manifold, mdx, noise, pitch, pitched, pulley, stethoscope
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
