Turn signals light up but won’t blink
Old 10-25-2022, 01:15 PM
White_EG1's Avatar
Default Turn signals light up but won’t blink
The only thing I did was do a wire tuck and cut some of the abs wires and srs ones and sealed with electrical tape.
Turn signals were working fine before this. The back signals blink but fast and the back hazards blink, the front is illuminated but no blink from the signals or hazard
Replaced hazard switch and turn signal relay with known good ones. I’m getting battery voltage to both as well. Cleaned g201 ground on the fender frame rail since I tucked and grinded it to bare metal for a better connection same with g401 ground
Headlights work too just no front signals
Old 10-26-2022, 05:45 AM
White_EG1's Avatar
Default Re: Turn signals light up but won’t blink
bump
Old 10-26-2022, 04:12 PM
__Ek__'s Avatar
Man it seems that you either connected a wire wrong somewhere, or cut a wire. The only thing I can thing of to do is double check each connection. Thats pretty much about the only thing it can be, either that or check fuses and relays. Maybe check turn signal/hazard relay? Idk man, hard to figure this kinda stuff out without looking at it.
Old 10-26-2022, 05:05 PM
White_EG1's Avatar
I just replaced the bulbs and they work now weirdest thing ever
Old 10-26-2022, 08:14 PM
JRCivic1's Avatar
Wow, that is MUCH easier than what I was suggesting you look at in your other thread. Glad you got it working.
Old 10-26-2022, 10:30 PM
__Ek__'s Avatar
That is pretty weird ha, must of blew em during tuck somehow? idk ha.
Old 10-28-2022, 01:21 AM
wunfstgsr's Avatar
It's funny this used to happen to me when I would pull the bulbs out my corner signal lights in my integra! when i would mess with my intercooler or something i would need to remove the signal lights and bulbs and this would happen! the only thing i found to make it work was plug in the bulb and plug it out the socket and give it a good snap putting it back in the corner housing.
Old 10-29-2022, 09:43 AM
O.G. triple O.G.
NVturbo's Avatar
bulbs were dual filament bulb. The filament for the turn signals were likely burnt out. I'm guessing they were 1157 bulbs.
superfly23
Honda CR-V & Element
02-22-2016 01:00 PM
h23isnotabigblock
10-14-2008 05:10 AM
amit_b82
10
03-02-2008 08:39 PM
ogawa_jiei
09-23-2006 06:10 PM
B2FiNiTY
09-20-2001 01:20 PM
Quick Reply: Turn signals light up but won’t blink
