Ecu issues
Old 10-27-2022, 03:55 PM
Praetor7154's Avatar
Default Ecu issues
I have a 00 civic with a jdm b18c with gsr trans, no marking on ecu, and absolutely no communication through obd port with fox well 510 elite programmed for Honda. How can this be fixed, and how to find what ecu was installed on car.???
Old 10-27-2022, 04:39 PM
Chance EG's Avatar
Default Re: Ecu issues
Picture of the inside of the ECU may help. Open the lid.
Also looks like someone got halfway done removing the AC and PS and then bailed...
Old 10-27-2022, 05:51 PM
Hysterically Calm
TomCat39's Avatar
And the plugs in the ECU look to be OBD1 plugs and that looks to be like an OBD2 to OBD1 conversion harness, possibly home made. OBD1 will not read on a scanner.
Old 10-27-2022, 07:40 PM
JRCivic1's Avatar
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ THIS !!!
Old 10-28-2022, 05:50 AM
Ryanthegreat1's Avatar
There are scanners for OBD1 on the three wire diag plug. The foxwell isn't one of them.
Autel MS906BT is one example.
Old 10-29-2022, 05:11 AM
theYBLEGAL's Avatar
IMO there is nothing to fix, that's better than having an OEM obd2 ecu that isn't meant for that motor just so you can hook up a scan tool. The obd1 ECU is hopefully tuned. You can pull codes without a scan tool using the service jumper. Easy Google search. I would never buy a scan tool for obd1 Hondas.
Unless you are dealing with emissions restrictions...it's fine.
Old 10-30-2022, 08:05 AM
Hysterically Calm
TomCat39's Avatar
The average Joe isn't usually going to have a 1500 dollar scanner laying around with the Honda Adapter to go with it. There is another cheaper option Hondash if I recall. Just not sure how far they got with the project.
Old 10-30-2022, 03:47 PM
I agree but there are tools out there for reading OBD1 Honda stuff.
ScubaStevesVtec
Honda Civic (2001 - 2005)
08-25-2006 04:19 PM
revtech motorsports
03-23-2005 03:50 PM
nfn15037
03-20-2005 10:32 PM
paulyman
03-31-2002 05:26 PM
Quick Reply: Ecu issues
