High Idle and misfire codes.
Old 02-16-2015, 06:37 PM
MyDad'sCivic's Avatar
Default High Idle and misfire codes.
I have a civic ex 1999 with about 230k miles in the motor and after a oil change and topping up the coolant the car started to throw the codes P0301,P0302,P0303,p0300 abd p1399 and sometimes the p0505 code with a high idle*about 1.3k*.I changed the IACV, spark plugs and bleed the coolant and its somewhat better but it still throwing the same codes. I suspect it is a vacuum leak but i cant find where exactly. What steps should i take ?
Old 02-16-2015, 07:04 PM
Former User's Avatar
Default Re: High Idle and misfire codes.
How old are the distributor cap, rotor, and plug wires?
P0505 - check for a disconnected vacuum hose.
Old 02-16-2015, 07:32 PM
About 4 years i think and ive checked on top of the mani and there is no hoses disconnected
Old 02-16-2015, 07:34 PM
Originally Posted by MyDad'sCivic
About 4 years
Replace them.
What Civic trim and engine?
Old 02-17-2015, 08:33 AM
Kitami Jun's Avatar
I detected a vacuum leak from the throttle body gasket and my intake manifold gasket by spraying carb spray over these components. You can try and spray certain suspected areas to see if the engine reacts.
Old 02-17-2015, 10:16 AM
Originally Posted by RonJ@HT
Replace them.
lol i said the trim on the op but wtv. It's a EX with the d16y8 i believe
Will do thanks
Old 02-17-2015, 10:20 AM
Sorry, missed it.
Here are the vacuum hoses to check:
Old 02-17-2015, 11:56 AM
Fixed it. It was the CC vacuum hose that was disconnected. Good thing i didn't buy anythign expensive lol
washpawryder
10-11-2012 01:24 AM
mudpuppy4life
08-10-2012 04:37 PM
turboedsupe
05-10-2009 02:17 PM
DOHC Kid
05-02-2008 11:36 PM
Quick Reply: High Idle and misfire codes.
