high idle
Old 04-11-2011, 10:16 AM
hondaboi7's Avatar
Default high idle
i have a ls/vtec with a type r head.has vtec controller..idle surges for ~4sec(when start) then it is stuck around 1k rpm when warmed..iacv was cleaned,throttle screw is closed,fast idle valve was turn all the way, timing is lined up..when the tps was unplug, idle came down to ~700 but bogs??..im in 5th gear doing 40mph n rpm is ~2200 and ~2500 at 50mph..any help would be great.thanks
Old 04-11-2011, 11:31 AM
DeLSoLRo's Avatar
Default Re: high idle
so if you let go of the clutch in first it wont die?
Old 04-11-2011, 11:33 AM
hondaboi7's Avatar
no it doesnt die..rpm is stuck at 1k..
Old 04-11-2011, 11:41 AM
DeLSoLRo's Avatar
go on here it has a good list of possible things that might be the cause for idle problems.
http://www.team-integra.net/forum/19...iming-adj.html
if nothing works try to find a friend that can let you use his iacv, ecu, throttle body and see if it will still do it with those exchanged.
Old 04-11-2011, 11:42 AM
DeLSoLRo's Avatar
sometimes it might be a bad gasket or bolts that are not tight enough. It's aggravating as hell trying to figure it out when youve tried almost everything.
Civicfanatic_09
17
07-16-2012 12:04 AM
B18_badboy
05-01-2011 04:43 PM
cstone
01-17-2011 07:42 PM
B16CRXT
07-19-2004 11:06 AM
sohcVtec_1
06-03-2004 07:37 PM
Quick Reply: high idle
