High beams work low beams do not
so when i have my high beams on they work just fine but if i switch to low beams my lights altogether turn off. but sometimes the low beams will stay on for a little bit and slowly get dimmer and dimmer untill it turns off
Re: High beams work low beams do not (eghatchin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatchin »</TD></TR><TR><TD CLASS="quote">replaced bulbs and does the same thing</TD></TR></TABLE>
Then it's a bad wire, or connection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">check ur fuses...
If it was a bad fuse the bulbs wouldn't work at all.
Re: (eghatchin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatchin »</TD></TR><TR><TD CLASS="quote">could it possibly be the plug going to the bulbs</TD></TR></TABLE>
It could be the plug which would mean it's the wiring like I said earlier, however, it is odd that the wiring is messed up on both sides.
It looks like I may stand corrected. I looked at a fuse diagram, it looks like there are fuses for both high and low beam. Can you please verify this and check to see if your low beam fuses are blown? They should be 10A fuses.
Re: (eghatchin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatchin »</TD></TR><TR><TD CLASS="quote">have checked and they were not, but if the fuses were blown why would they work for a little bit once and a while </TD></TR></TABLE>
Sometimes fuses don't completely blow, they crack a little allowing the component to work.
Re: (mechanix619)
i hate to quote myself but...
Re: High beams work low beams do not (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">You may have a bad combination switch on the steering column.</TD></TR></TABLE>
yea or a wiring problem
civicx
12-13-2016 05:32 AM
