Help!!! Wiring for a D16Z6 into a 92 VX hatch!!!
Help!!! Wiring for a D16Z6 into a 29 VX hatch!!!
Ok guys, I TRIED DOING SEARCHES ON THIS So please just help me out. I have a 92 VX hatch and I just put a D16Z6 motor in it. My question is what to do with the 4th connector plug on the shock tower???? On my vx motor it had 4 plug on the engine harness to match the four plugs on the shock tower but the D16Z6 motor only has 3 plugs on the engine harness so what do I do with the 4th plug on the shock tower harness?????
Thanx
Thanx
Re: Help!!! Wiring for a D16Z6 into a 29 VX hatch!!! (112480)
the 4th plug on the pass strut tower is for the 5 wires wide band o2 on your vx, you need to convert that into 4 wires o2 for your d16z6 motor, basicly you need to swap out 1 wires from that plug into other plugs.
Modified by 2lua at 8:08 AM 4/9/2004
Re: Help!!! Wiring for a D16Z6 into a 29 VX hatch!!! (2lua)
um I'm kinda confused could you explain that a little more in detail please.
Re: Help!!! Wiring for a D16Z6 into a 29 VX hatch!!! (95hatch)
Don't try to use the Z6 harness. Use your old VX harness, the only additional wiring necessary will be to convert the VX wideband Oxygen sensor to the standard 4 wire oxygen sensor.
Here is a thread with pretty pictures to help you convert your oxygen sensor... https://honda-tech.com/zerothread?id=295330
I should add that there will be a 3 wire plug on the harness that will be left over, this was for the EGR on the VX; as long as you use the proper ECU you can just let that plug dangle.
Modified by powerofdreams8 at 3:51 PM 4/9/2004
the fourth plug in the VX is a 6 pin connector with four wires that run ito it. you need one of those wires. The orn/blu wire in pin 6, it's the O2 sensor signal. Pull it out of the plug carefully and put it in the 10 pin connector in location 2.
if you're lost which wires I mean or their locations look here http://www.b18c5eg.com/itr_vx_wiring.html. Just ignore the rest of the wiring, it's for a C5 into a VX.
The 6 pin is C129 that you only need the one wire from and the 10 pin is C102 that you need top put the wire into. The rest is completly plug and play from the Z6 engine harness into the VX car harness.
Re: Help!!! Wiring for a D16Z6 into a 29 VX hatch!!! (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the fourth plug in the VX is a 6 pin connector with four wires that run ito it. you need one of those wires. The orn/blu wire in pin 6, it's the O2 sensor signal. Pull it out of the plug carefully and put it in the 10 pin connector in location 2.
The 6 pin is C129 that you only need the one wire from and the 10 pin is C102 that you need top put the wire into. The rest is completly plug and play from the Z6 engine harness into the VX car harness.</TD></TR></TABLE>
THANX BRO!!!!!!
THANX BRO!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatch »</TD></TR><TR><TD CLASS="quote">yea i think thats his problem, there is some compatibility issues with a z6 going into a 1929 hatch. </TD></TR></TABLE>
Haha guys, very funny. You know what I meant
is ur car throwing a cel? i have a vx with a z6 in it and there are no cels now that i accually have a o2 sensor.
check engine light. read here http://www.c-speedracing.com/faq/03.php
Oh ok, I didn't know cel was short for check engine light. Well in that case, no my car isn't throwing a cel either, which is good to me b/c it was throwing a cel right before my old motor blew.
crowscare
09-23-2012 09:43 PM
kajay1972
09-08-2007 07:35 AM
spooolin
08-08-2006 08:49 PM
someforlight
03-26-2005 06:11 PM
