HELP WILL THIS FIT????
Old 03-20-2007, 01:04 PM
jarven093's Avatar
Default HELP WILL THIS FIT????
i have a 93 civic EX with the D16Z6 motor and i need to know will a transmission from a 97 civic ex with a D16z6 or it may be a Y8 but i herd they are pretty much the same. but any way will the tranny from that 97 civic fit my 93 civic i also know the interchange parts are 92-95 but is it an exception for the tranny??? they are both a hydrolic clutch set up??? please help
jared
Old 03-20-2007, 01:11 PM
(banned)
Jizzmaster Zero's Avatar
Default Re: HELP WILL THIS FIT???? (jarven093)
Yes.
Old 03-20-2007, 01:15 PM
eg8tuner's Avatar
i am putting a whole y8 setup in and i had to change my speed senors from one to the other cause the plug is firrent other than that it looks exactly the same
Old 03-20-2007, 01:16 PM
jarven093's Avatar
Default Re: (eg8tuner)
Awsome thanks guys for the help !
Old 03-20-2007, 01:48 PM
95ProjectEJ1's Avatar
Default Re: (jarven093)
It will work, i have the y8 on my d16z6. Can someone verify that the clutch for the z6 and y8 are the same?
Old 03-20-2007, 02:35 PM
a milano fred's Avatar
Default Re: (95ProjectEJ1)
you should be able to swap the tranny without major probs since most d-series parts are interchangable. and the y8 has steel shifter forks as the z6 is aluminum, also i believe that gears are closer on the y8 so it would be a nice upgrade with your z6 motor.
i believe that the clutch will fit, i know that the exedy clutch fits for 91-00 d-series trannies. (ref: http://www.superhonda.com/foru....html)
rx_86
01-05-2009 04:34 PM
amej8
06-03-2008 01:15 PM
SEATownboi08
02-20-2008 07:09 PM
DeviousCTR
09-01-2004 05:40 AM
Quick Reply: HELP WILL THIS FIT????
