help on vtec solenoid bolt size and valve cover bolt size
sup guys, i got a d16y8 head but i dont know the bolts size for the vtec solenoid as well as the valve cover. anyone know the bolts size and length. thanks in advance
Re: help on vtec solenoid bolt size and valve cover bolt size (Ignitecivic)
I know theyre both 10mm heads. solenoid im not sure on length. and on the valve cover do you mean the stud or nut? if its the stud those are special order from the dealer, the nut any 10mm nut will work.
Re: help on vtec solenoid bolt size and valve cover bolt size (rewsnaeht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht »</TD></TR><TR><TD CLASS="quote">I know theyre both 10mm heads. solenoid im not sure on length. and on the valve cover do you mean the stud or nut? if its the stud those are special order from the dealer, the nut any 10mm nut will work.</TD></TR></TABLE>
Re: help on vtec solenoid bolt size and valve cover bolt size (Skunk2whore)
aite cool. imma try to get some bolts for it. i looked at the helms and it said 6 x 1.0 mm dont understand what thats mean.
a c i d.f l y
02-11-2013 09:57 PM
skaternak
12-19-2009 08:02 PM
acake em1
04-30-2009 08:21 PM
