Help!!! Tires rubbing on inner fender!!??!!
I've got a 98 ex, I just bought some 16" rota sub-zeros with 205/45 dunlops, and they are rubbing the inner fender when I turn, what do I do? I have coilovers so I could adjust them, but it seems that they are rubbing on the inside,so adjusting my coilovers might not help. I'm pissed I can't really drive right now, someone help!!
Re: Help!!! Tires rubbing on inner fender!!??!! (UtahRockabilly)
I have a 98 Civic Ex Coupe. I had the same problem when I had 17 inch rims. I was dropped around 2.5 inches, and never had a rubbing problem untill I put in a camber kit. In the rear I rubbed so just under the wheel well there should be a rubber liner, i took a hammer and bent that in enough so I didn't rub anymore. Dont bend it too much it will actually crack the paint. For the front, my tires rubbed for a while but now when I take off my rims I can see where it rubbed and left a good size indent but after a while it never did it again. I'm sure it only rubs when you cut the wheel real sharply. I wouldn't worry about it. If its that big of a problem then get tires with a smaller wheel wall.
I'm slammed about 2.25 or 2.5 inches and yea it only rubs when I cut it real hard I guess I'll either try to pound it in or just wait it out I guess,
Re: Help!!! Tires rubbing on inner fender!!??!! (NTRCULD)
Re: Help!!! Tires rubbing on inner fender!!??!! (8grandEG)
keep it slammed....i think you should take your fenderlining out...be a man.
Re: Help!!! Tires rubbing on inner fender!!??!! (B2FiNiTY)
raising it up is almost out of the question, almost, If I can't get the inner fender to work with me I may have to, but I sure as **** don't want to. It looks and drives way too good to raise it at all. I've only really noticed it when I'm going around a corner and hit a bump, (there are a lot of bumps here), then it rubs kinda bad. On a separate note, these wheels are perfect for my white ex, those rota sub-zeros, steel gray with the polished lip, they're replicas of the racing hart CPO35, whatever, they're dope, I'm going to post some photos, so look for'em.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8grandEG »</TD></TR><TR><TD CLASS="quote">i think you should take your fenderlining out...be a man.</TD></TR></TABLE>
Taking your fender lining out screw up a lot of ****. Not to mention throwing all kinds of dirt on your door hinges, which will cause them to prematurely fail. Why ruin a good car for a set of $200 springs???
Go buy a set of real springs, like the Tein S for $150.
Jon Black
Jon Black
2000EJ8
Suspension & Brakes
26
02-26-2009 05:18 AM
