b16 tranny problem in 5th
i open my tranny just before making my swap and i swich everything that where wrom inside of it, i put a lot of new stuff in it and i put oil in it, later on my dad accidentally take out one nut and i leak like almost 1/4 of a botter of oil, and my 5th gear when am driving and u let go the gas i came out? what is causing this? i need oil? and also when i put 1st and i let go the clutch slowly it feels like if jumping? comment pls
Re: b16 tranny problem in 5th
nop i never have it before and i open it and i put everything on it new and i were sure that every sincro and gear were good, i just put the swap, oil, it leak, no put more oil, and is doing this
i will see because you can put 5 and it run normal no always the gear come out but 2 from 6 time it does, so i will see if i can fix this againg i took it to a shop and they did for me
I had a similar problem in mine when i swaped my motor and tranny. When i was driving in fifth gear the tranny would just pop out of gear. I though I had a busted tranny but all it needed was some more tranny fluid because it was very low on oil and after I refilled it, it ran smooth from there on.
Seagull Management
popping out of 5th is usually a sign of low fluid. If you keep running it like that it'll start to burn gears and eventually they'll start welding themselves to mainshaft.
