Help with spongy brakes
Old 07-12-2009, 05:05 PM
-iLLuZioN-B18C1's Avatar
Default Help with spongy brakes
Ok, so I bought new pads and bled all 4 corners with new brake fluid but my brakes are still spongy. I push the brakes and it stops fine, but when I get to a red light while Im stopped, the brake pedal keeps slowly going in until im almost at the floor.
Could I have bad brake lines? Car does have 163k miles so thats my next guess.
Thanks
Old 07-12-2009, 05:12 PM
Former User's Avatar
Default Re: Help with spongy brakes
Thoroughly rebleed the system in the correct wheel order.
Old 07-12-2009, 05:17 PM
Im confident I did. right rear, left rear, right front, left front. I did it until there were no bubbles and new fluid was coming through.
Old 07-12-2009, 05:19 PM
If the brakes were properly bled and you can't detect any leaks, then replace the master cylinder.
Old 07-12-2009, 05:23 PM
itsmejto's Avatar
Yup, same here, master cyl is leaking by the seals, common problem you describe.
Old 07-12-2009, 05:55 PM
are you refering to the rod seal?
Old 07-12-2009, 06:16 PM
If you don't have a leak, then the rod seal is fine. The problem would then be internal to the master cylinder, which you would need to replace.
Old 07-13-2009, 12:16 PM
ok, thanks!
94 IntegraLS
21
06-11-2012 08:41 PM
EJ1_Sleeper
09-08-2009 12:09 PM
93CamaroLT1
11-15-2008 01:27 AM
drew2
02-12-2006 01:19 PM
89dxhunchback
04-05-2005 02:05 PM
Quick Reply: Help with spongy brakes
