HELP: solid CEL and blinking SRS Light - Honda-Tech
Closed Thread
Old 07-02-2010, 03:56 AM   #1
Default HELP: solid CEL and blinking SRS Light
95 civic with a d15b vtec swap, my CEL light comes on when i crank my car. I jump off the CEL light to flash codes and the CEL just stays steady with no blink and the SRS light starts to blink... kinda weird guys!! someone said i could just unplug the SRS light form the cluster and it would ignore the SRS system and then flash my codes on the cel light.
streethondar is offline
Old 09-24-2010, 09:19 AM   #2
Default Re: HELP: CEL Aan Blinking SRS Light
I got the same srs issue as you, hope someone gets back with a clarification. Im in a 98 CRV.
laloquera916 is offline
Old 09-24-2010, 10:48 AM   #3
virgineg6's Avatar
its worth a try, dont leave it disconnected though cuz if u get in a accident ur bags wont deploy
virgineg6 is offline
Old 09-24-2010, 11:47 AM   #4
Default Re: HELP: solid CEL and blinking SRS Light
You have CEL code 0. See CEL sticky at the top.
Does the engine start and run?
Former User is offline
Old 09-27-2010, 09:26 AM   #5
Cell code 0? I got a 55 from my SRS light. Is this called the "S" light also?
Old 07-06-2011, 05:17 PM   #6
I have the same issue with my at. : 95 civic 16z6: it sputtered and died and had no spark bit Now it's doing the same: CEL stays on, SRS flashes same intervals forever. What's the issue? Distributor?
RuddyDuck is offline
Old 05-10-2015, 08:08 PM   #7
Icon7 Re: HELP: solid CEL and blinking SRS Light
I had the same problem. I was driving and the car just suddenly dies. I pull over, jumper the diagnostics connector and the CEL turns on and the SRS light just flashes endlessly. The Car will not start.
I tow it home and started to try to figure it out.
First I found a loose battery cable(oops).
The starter worked even with the loose battery cable.
I tightened it but still it would not start.
No Fuel pump Hum.
No power to the fuel pump.
fuel pump works when jumpering 5 and 7 connector on the fuel pump relay.
replaced the fuel pump relay...No joy.
I never checked for spark.
I remembering reading not to disconnect power with the key on or engine running or it could hurt the ECU.
So i replaced the ECU. Whooo Hooo!
I have a car again.
So my guess is the continuous flashing SRS light while checking for codes means something is wrong with the ECU, in my case total death.
jmhiii is offline
Old 05-10-2015, 08:12 PM   #8
Old thread locked.
Closed Thread
My 1994 honda civic lx sedan check engine light stays on Cheerleader23 Honda Civic / Del Sol (1992 - 2000) 10 10-25-2015 05:08 PM
CEL 95 civic moto310 Honda Civic / Del Sol (1992 - 2000) 2 11-19-2007 06:49 PM
SRS code list? -Todd- Acura Integra 14 03-25-2006 03:13 PM
CEL Help ipleadthe5th Acura Integra 6 12-09-2004 08:48 AM
CEL b18c1 hybrid??? jl21ah Tech / Misc 6 11-08-2002 11:18 PM
Tags
95, 98, accord, blinking, cel, check, civic, engibe, flashing, flickering, honda, light, prelude, solid, srs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
