help with removal of door handles
Old 08-09-2004, 08:31 PM
raybord's Avatar
Default help with removal of door handles
do you have to remove interior door panel in order to access the door handles for removal? thanks--
Old 08-09-2004, 08:38 PM
Revolver's Avatar
Default Re: help with removal of door handles (raybord)
Interior or exterior handles? Year?
Old 08-09-2004, 11:27 PM
menkio's Avatar
Default Re: help with removal of door handles (Revolver)
none of thoose question matter, goto autozone and get a door handle remover tool, it's a thin metal tool with a u cutout in the middle. put it at the very base of the handle and door panel and turn, done. then the door panels pop off, you might have 1 or 2 screws in the panel btw the controls. any problems msg me
Old 08-10-2004, 06:41 PM
raybord's Avatar
Default Re: help with removal of door handles (DewMota)
its the exterior door handles on a 95 civic coupe
Old 08-10-2004, 07:03 PM
becker98's Avatar
It would be a good idea to take the panels off. There are a few rods that atach to them that you have to take off probally more stuff to. Why are you taking them off
Old 08-10-2004, 07:21 PM
menkio's Avatar
Default Re: help with removal of door handles (becker98)
this takes 10-15 min's to do... do what i told you and get to work.. done. any problems msg me
Old 08-11-2004, 04:12 PM
UltRaH22's Avatar
remove 2 screws.. one in oval handle piece, one behind inner door handle, pop the clip off between the panel and the window crank, then the crank pops off, one plastic screw up near mirror then the panel pops off.... u might have to cut the plastic lining inside the door and theres 2- 10mm bolts holding the handle on... after that u need to pop the plastic rivet out that h0lds the handle to the metal rod.and theres also something goin to the door lock u need to disconnect as well.
Old 08-11-2004, 04:59 PM
struppi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">none of thoose question matter, goto autozone and get a door handle remover tool, it's a thin metal tool with a u cutout in the middle. put it at the very base of the handle and door panel and turn, done. then the door panels pop off, you might have 1 or 2 screws in the panel btw the controls. any problems msg me</TD></TR></TABLE>
You must be talking about a tool to pop off the clip on the window crank. You really don't need a special tool for that.
lshatch916
06-24-2007 06:03 PM
eL
Honda Civic (2006 - 2015)
12-19-2006 05:02 AM
XViEtBoiX
Honda Civic (2001 - 2005)
12-16-2006 10:38 AM
CWBETB
12
07-01-2005 07:18 AM
JDM EJ1 95
03-25-2004 03:13 PM
Quick Reply: help with removal of door handles
