Help: Rear trailing arm bushing question.
Old 01-19-2009, 04:52 PM
cangrin's Avatar
Icon6 Help: Rear trailing arm bushing question.
I have a 93 Civic HB with the rear trailing arms/brake swap from a 93 Integra. The stock trailing arm bushings were needing to be replaced. So I purchased some performance bushings for a 92-00 civic because I thought that they would be compatable, but the bushings seem to be to small around. What is the differance between EG civic trailing arms and 90-93 integra trailing arms?
Old 01-19-2009, 09:49 PM
danomatic93's Avatar
Default Re: Help: Rear trailing arm bushing question.
yes. you got it. I usually suggest 94-01 tegi T-arms or 92-00 civic T-arms with disc. You'll have to get the correct bushings for a 90-93 tegi.
Old 01-20-2009, 05:33 AM
honda.lioness's Avatar
Trailing Arm Bushing p/ns
-- for 90-93 Integra 52385-SK7-N02 (larger diameter than Civic's below)
-- for 1988-2000 Civics 52385-S21-0003 (formerly was 52385-SR3-000)
This comes up a lot on Honda and Integra fora. E.g. see
http://www.performanceforum.com/wesv...g/bushing.html
http://www.tegger.com/hondafaq/rustybrakes/brakes4.html
https://honda-tech.com/forums/suspension-brakes-54/rear-trailing-arm-bushing-rta-part-number-1960010/
Old 01-20-2009, 08:31 AM
cangrin's Avatar
Thank you honda.lioness and danomatic93 for your help. That answered my question.
Old 01-20-2009, 08:36 AM
keving85's Avatar
those bushings are a pain in the *** to install..... if you press them in wrong they are known to tear up........ i had to take mine to honda..... 50 bucks and i brought them the trailing arms and new bushings....
kev
Old 01-20-2009, 08:41 AM
JShull's Avatar
Make sure you mark the way the bushing was clocked before you take it out so you can match it up on the install.
Here's a great thread if you need a how-to as well:
https://honda-tech.com/forums/showth...t=arm+trailing
Old 01-20-2009, 09:50 AM
InTheZoneAC's Avatar
there's an arrow on each bushing showing which side faces down. Luckily my trailing arms had markings to point exactly where top center and bottom center line up so didn't need to mark anything.
mofo951
Suspension & Brakes
03-10-2012 12:23 PM
cangrin
01-19-2009 10:40 PM
serb_rida
Suspension & Brakes
06-19-2008 04:16 PM
Timberland237
11-20-2006 08:00 PM
.:TNN:RumbleN:.
06-25-2004 03:45 AM
Quick Reply: Help: Rear trailing arm bushing question.
