Help! Raddling sound when starting in 1st gear from stop...
Old 08-27-2004, 09:58 PM
yonnage's Avatar
Default Help! Raddling sound when starting in 1st gear from stop...
Hey all,
Just tonight my car started making a pretty loud raddling noise when I am starting to go in 1st gear from a stop. As i let go off the clutch and give it some gas, a loud raddle can be heard from the front of the car (middie/driver side i think). As I accelerate it stops, and then it can be heard just slightly as I shift into 2nd and let go of the clutch.
Any ideas?
Thanks
Old 08-27-2004, 10:26 PM
crashN2u's Avatar
Default Re: Help! Raddling sound when starting in 1st gear from stop... (yonnage)
Low rpm only? It could be a loose heat shield.
Old 08-27-2004, 10:33 PM
evilcivilian's Avatar
Your exhaust pipe.. underneath the car, theres a shield that tend to go loose on many hondas. I had the same problem with my car, i just went underneath the car and literally sawed it off because the bolts were all stripped .. problem solved.. save weight too
OR, i could be wrong and your heat shield
Old 08-27-2004, 10:56 PM
beandip's Avatar
Default Re: (evilcivilian)
[QUOTE=evilcivilian] i just went underneath the car and literally sawed it off because the bolts were all stripped .. problem solved.. save weight too
QUOTE]
LMAO
Old 08-27-2004, 11:10 PM
JDM R's Avatar
Default Re:
most likely its jus a heat shield, i say check that first
Old 08-28-2004, 03:50 AM
Ajax's Avatar
Default Re: Re: (JDM R)
Badass I've been wondering what that shaking was for a while
Old 08-28-2004, 06:45 AM
yonnage's Avatar
Default Re: Help! Raddling sound when starting in 1st gear from stop... (crashN2u)
Awesome... I'll check later today and post back here..
Thanks!
Backk InTheDA
10-20-2009 02:52 PM
CNSK
Honda S2000
13
02-13-2009 07:55 AM
Civicvtihatch
10-09-2005 12:39 PM
Harley999
07-08-2004 02:52 PM
ID_ten_T
05-20-2004 07:49 PM
Quick Reply: Help! Raddling sound when starting in 1st gear from stop...
