Help with PCV Valve for Civic EX 1999 - Honda-Tech
Old 04-28-2005, 06:35 PM   #1
mushu315's Avatar
Default Help with PCV Valve for Civic EX 1999
I searched everywhere...
I found one diagram, but i dont understand it, and i still can't find it.
can someone post up a picture of the actual engine and location of the PCV Valve?
I found pics for Accords, cRX, but no Civics
Thanks
mushu315 is offline   Reply With Quote
Old 04-28-2005, 07:22 PM   #2
Bond's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (mushu315)
Thanks
I would start off by looking at the intake manifold .
Bond is offline   Reply With Quote
Old 04-28-2005, 08:05 PM   #3
92civic_eg's Avatar
hello
it is under the intake manifold,which you would need to go under the car and replace it
92civic_eg is offline   Reply With Quote
Old 04-28-2005, 08:30 PM   #4
Bond's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (92civic_eg)
Quote:
Originally Posted by 92civic_eg
hello
Well I don't know about that. On EG's they are on top of the intake manifold close to the valve cover. I can't see why they would put it underneath on the 99.
Old 04-29-2005, 07:21 AM   #5
EE_Chris's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (Bond)
Why don't you just get underneath and look up above the oil filter - it IS underneath the manifold.
EE_Chris is offline   Reply With Quote
Old 04-29-2005, 07:47 AM   #6
flood's Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (EE_Chris)
Correct its under the intake mani.
When you change the oil is the best time to do it. Take off the oil filter and there is a black box just above it. Plugged into the black box is the PCV valve with attached hose. You can pop it out carefully with a screwdriver. Then crawl out from underneath your car (safely supported with jackstands) and pull the hose that the PCV is attached to from between your intake runners and pop in the new valve. Crawl back under and put it in the black box. Finish oil change.
flood is offline   Reply With Quote
Old 04-29-2005, 08:32 AM   #7
#1 Super Guy
94eg!'s Avatar
Default Re: Help with PCV Valve for Civic EX 1999 (flood)
It took me and my friend about 20 minutes to find it on his EX. I couldn't believe they started putting those things underneath the intake manifold. They are hard enough to get out when there on top. Good thing he had small hands and could get the stupid thing out of the oil separator can though. I couldn't even get my hand in there far enough to get a thumb on it.
94eg! is offline   Reply With Quote
Old 04-29-2005, 09:17 AM   #8
sohcmasta's Avatar
well, they're not exactly an everyday maintainance kinda thing, so it makes sense to put them outta the way.
sohcmasta is offline   Reply With Quote
Old 04-30-2005, 03:34 AM   #9
mushu315's Avatar
damn, that's a pain.
so if i want to replace it, do i just pull it off?
anything special i gotta do?
THansk
PCV valve replacement interval Zebra Honda Civic (2006 - 2015) 2 09-06-2016 12:58 AM
pcv valve location? Turbochargedcivic Honda Civic / Del Sol (1992 - 2000) 3 08-02-2006 09:04 AM
NEED HELP!!!! WHERE IS MY PCV VALVE. D16Y8 REPOSSESSEDHX Honda Civic / Del Sol (1992 - 2000) 1 10-14-2005 03:21 PM
is a pcv needed b18c-93 Drag Racing 8 11-28-2003 07:29 PM
where's the pcv valve briangela1 Honda Civic / Del Sol (1992 - 2000) 4 06-09-2002 11:29 AM
Tags
1999, 99, civic, honda, install, location, lx, pcv, pic, picture, replace, replacement, replacing, valve, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
