help needed with srs system
hi guyz i had to take my cluster out of my 95 civic ex coupe since i needed to test jdm cluster, and i disabled airbag under the steering wheel when i put everything back togheter, my SRS airbag light is on and does not go off any one any clues, how to reset it , and to make it go away?
thanks sk
thanks sk
Re: help needed with srs system (vtecvoodoo)
VTECVOODOO!!! YOOOOO!!
isn't that just great, im seein the voodoo for vtec in the front row -- err, my front seat i should say
[Modified by poison, 12:51 PM 5/30/2002]
Re: help needed with srs system (skeletaz)
there is a harness that is not plugged in, could be the passenger's, could be the driver's loose, could be the SRS unit harness that's loose, trial and error
Re: help needed with srs system (sushtsi)
What colour are the harnesses? And what does they plug into? Is it a seperate srs computer? Or does it plug into the ecu?
no mine is pluged in i think, since only thing i unpluged was drivers air bag and i am preaty sure that it is conected ok, now still is there is any way to reset it to make sure, like keeping fuse out or something
There has to be something faulty, or a blown fuse, check your fuse box under the dash, and look at the SRS fuse.
greenmonster
04-28-2004 10:04 PM
travis
02-15-2002 02:04 PM
servion
01-18-2002 09:04 PM
