HELP! MY CAR BOGS AT LOW RPM - Honda-Tech
Old 09-08-2009, 06:03 PM   #1
EJ8-Yao's Avatar
Default HELP! MY CAR BOGS AT LOW RPM
So, I have my 96' EJ8 for a while now and recently It has started to bog at low RPM. Let's say I'm going 35mph at like 2 or 3K and when I step on the gas a little to speed up, It lags, Bogs for a little bit and I'd step on the gas harder and it'll be normal again. I just replaced my Fuel Filter today and it's still doing the same thing..Anyone ever encounter this problem?? Thanks
EJ8-Yao is offline   Reply With Quote
Old 09-08-2009, 07:34 PM   #2
Jimster480's Avatar
Default Re: HELP! MY CAR BOGS AT LOW RPM
Quote:
sounds like your timing is a bit retarded.
Jimster480 is offline   Reply With Quote
Old 09-09-2009, 09:35 PM   #3
EJ8-Yao's Avatar
Quote:
So could my timing belt be loose or off? cuz I never messed with my timing belt before.
Old 09-09-2009, 09:48 PM   #4
check the distributor, mine does the same but from the start till 3k.
kiana60 is offline   Reply With Quote
Old 09-10-2009, 12:02 AM   #5
skaternak's Avatar
take out the fuel rail and take out the injectors, clean the injectors and take out the filter for the injectors, clean the filter and injectors with carb cleaner. i would try that
skaternak is offline   Reply With Quote
Old 09-10-2009, 09:03 AM   #6
Jimster480's Avatar
Or you could just run some Techron through there along with Chevron gas (if its available) for a double shot of Techron. That cleans out fuel injectors pretty nicely.
Old 09-10-2009, 10:05 AM   #7
New User
It Happen to me one time, of Injectors didnt help, try new Spark plug, SP wires, dizzy cap..
exetrom is offline   Reply With Quote
Old 09-10-2009, 10:09 AM   #8
Last guy I talked with had a similar problem. Trying turning your car on and adjusting the distributor. If you timing is a bit retarded, that means you should adjust the distributor and advance it a little. If you mess with it, and then you use the throttle on the intake to see if it still bogs, you should be able to at least get it to normal that way.
fireblaze2k1 is offline   Reply With Quote
2000 Integra Gsr bogging, bad gas mileage. ThatDb8guy Acura Integra 26 12-01-2015 04:10 PM
HELP. B18B1 Bogging Down corys_ej8 Acura Integra 6 09-02-2011 07:12 PM
HELP! CAR IS BOGGING! EJ8-Yao Honda Civic / Del Sol (1992 - 2000) 1 09-08-2009 06:42 PM
bog problem?? h22 turbo strtricer1987 Honda Prelude 2 04-10-2008 12:15 PM
please help with bogging!! davidnguyen Tech / Misc 2 03-29-2004 10:35 PM
Tags
1994, 2000, 500, bog, bogging, bogs, car, civic, distributor, honda, low, makes, rpm, rpms, start, stays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
