Help: Idle Bogging Problem w/B20Z in EJ8
Old 12-17-2004, 12:19 PM
camelian's Avatar
Default Help: Idle Bogging Problem w/B20Z in EJ8
Background info: USDM B20Z2 block swapped in a 99 Civic Coupe running 7/10psi with a greddy kit and hondata.
Problem: Sometimes when I start the car, it will immediately start bogging (~200RPM) unless I give it some gas, and a lot of times it will just die completely. In order to start it again, I have to give it a lot of gas, and keep holding down the pedal for ~30secs after it starts, otherwise it will die again. (This problem occured even before turbo). Just a few days ago (after turboing), it died on the highway in the middle of driving when I released the clutch to get ready to downshift , pretty scary seeing how I was on a downsloping ramp and the brakes don't work well the the car is off. Any ideas as the the problem? The shop that did the swap and that installed the turbo can't seem to find out the problem either..
Old 12-17-2004, 07:21 PM
camelian's Avatar
Default Re: Help: Idle Bogging Problem w/B20Z in EJ8 (camelian)
anyone?
Old 12-20-2004, 07:12 PM
camelian's Avatar
Old 12-21-2004, 03:36 AM
EE_Chris's Avatar
Were you also using Hondata before the turbo install (or a stock ECU of some sort)?
Old 12-21-2004, 04:37 PM
camelian's Avatar
Default Re: Help: Idle Bogging Problem w/B20Z in EJ8 (EE_Chris)
before turbo i was just using a 92-95 LS ECU w/skunk2 OBDII->OBDI socket converter.
Do you think maybe it's the Idle Air Control Valve (or Valve Control..not sure of the order but you get my drift)?
Old 12-22-2004, 03:11 AM
EE_Chris's Avatar
Nah, it doesn't sound like a IACV problem to me - more like a fueling/timing issue.
What is the condition of your injectors/cap/rotor/plugs/wires and what are you using for them - OEM or aftermarket?
EphoraL
Classic Hondas
01-12-2013 12:02 PM
bigboom
10
05-13-2009 12:35 PM
Boost2NA
09-10-2002 02:33 AM
Ch33se
02-02-2002 08:39 AM
Quick Reply: Help: Idle Bogging Problem w/B20Z in EJ8
