HELP!! how to remove the window crank?
Re: HELP!! how to remove the window crank? (TenLarge)
Between the crank and the door panel there is a horseshoe shaped pin that you can remove with a flathead.
Re: HELP!! how to remove the window crank? (chowmien)
flat head works but you can also use a shop rag and slide it back and fourth so it will catch the end of the clip and pull it off youll understand when you see it.
lulz
yea flat head will work but the problem is that if your not careful the thing could go flying off and you wont find it. they make a special tool to take those things off its like a c-clip remover kinda.
dopamean
11-19-2008 08:22 PM
okman16
26
11-09-2003 12:48 PM
