HELP: Clogged Fuel Filter? Unsure
Old 02-24-2010, 07:58 PM
slikz714's Avatar
Default HELP: Clogged Fuel Filter? Unsure
Old 02-24-2010, 08:00 PM
forcefedferio's Avatar
Default Re: HELP: Clogged Fuel Filter? Unsure
It could absolutely be a clogged fuel filter. your symptoms are actually pretty common for that. i'd say it's a safe bet to start there.
Old 02-24-2010, 09:06 PM
jcdimvic's Avatar
i would change the fuel filter, if nothing else its cheap maintence
Old 02-25-2010, 01:06 AM
slikz714's Avatar
whats with the white smoke coming out of my intake after it sputters and shuts down when it can't turn on though?? is it burning gas or something? jw lol
it also makes a POOOF noise from somewhere just as it dies out..
Old 02-25-2010, 11:26 AM
slikz714's Avatar
helpp
Old 02-25-2010, 11:52 AM
slikz714's Avatar
i just took off my short ram intake and found oil on top of the throttle body? shiettt
Old 02-25-2010, 02:56 PM
e hahai's Avatar
The oil could be from the sputtering. You should change your fuel filter first and see if it starts.
Old 02-25-2010, 06:32 PM
slikz714's Avatar
will be changing asap!! could a clogged cat on my exhaust manifold stop it from starting also? my stock d16y7 exhaust mani has a crack on top near the o2 sensor but been running fine for the past few months and i dont have any check engine light on
Old 02-25-2010, 07:19 PM
e hahai's Avatar
If the cat was mounted after the exaust mani. it would'nt be much of a problem. Sense you have the exhaust mani. cat. it could cause a problem being it is so close to the head. What you could do for now( before you get a new one and you are sure its clogged) is remove it from your car and hollow it out. This is illegal in most areas so get a new one right away. Also watch out because if cold air gets in your head when the engine is hot it can wrap your head. But still change the fuel filter first.
guinnessstout
Honda Civic (2006 - 2015)
09-09-2008 09:12 PM
..::91TEG-G2::..
05-12-2004 06:47 AM
GSteg
11
03-22-2004 04:17 PM
Lei Siew Long
03-03-2003 04:52 PM
Quick Reply: HELP: Clogged Fuel Filter? Unsure
