help! check engine light wont turn off.
so im flashing a IAT sensor code, so i go to honda and buy a brand new sensor. cel is still on.
so i get a voltmeter and check voltage going into the sensor. and its getting wat it should. so wat the hell do i do to shut it off?
Is the cell still on for the same reason? have u checked? If so, then disconnect your battery not sure if its positive or negative cable, hell disconnect both this will re-set ur ECU. and if lights comes on again, then the problem still there.
Re: help! check engine light wont turn off. (longshot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longshot »</TD></TR><TR><TD CLASS="quote">so im flashing a IAT sensor code, so i go to honda and buy a brand new sensor. cel is still on.
disconnect the battery for about 5 minutes. it should clear the code.
i got it, i gfinally got it to shut the [freak] off.. so in case anyone cares, ...
red with yellow stripe and green wired plug goes to the iat, not the knock sensor.'
i had the plugs switched around. lol wat a noob *** mistake, when i am most def not a noob... thanks H-T
suimengher
Honda Civic (2001 - 2005)
02-20-2012 07:24 PM
greyejcoupe
10-03-2009 10:48 AM
