Help: Car wont go in gear when cold??
When i go out and crank up my car and it is cold I cannot get it in any gear. I play around with the shifter movin it up and down until it finally goes into gear. Once i get it in to a gear than it will go in the other gears fine. Once the car is warmed up than i have no problems with this at all. Anyone know what could be wrong or what i can do to fix this problem???
Re: Help: Car wont go in gear when cold?? (oldskooljdm)
try letting your car warm up for at least a couple minutes if it is cold out. Also, maybe you want to switch to a different oil weight for your tranny fluid... I know that certain weights are better for cold or warm weather, do a search and find out
I don't think it's a prob with the car though, I live in MN and mine doesn't like the cold very much either
Re: Help: Car wont go in gear when cold? (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp »</TD></TR><TR><TD CLASS="quote">Not to bring this debate back up, but you may want to try friction modified GM syncromesh.</TD></TR></TABLE>
That has sparked up quite large debates in the past, I've seen an old thread or two on the topic.
What oil are you running in the transmission right now?
sometime the syncros they contract cause of the cold weather.. so metal needs time to heat of... anyways your suppose to let your car heat up before you just in and drive away
Re: (Houston Hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Houston Hatchback »</TD></TR><TR><TD CLASS="quote">sometime the syncros they contract cause of the cold weather.. so metal needs time to heat of... anyways your suppose to let your car heat up before you just in and drive away</TD></TR></TABLE>
um..thats also debatable..about the whole warming up your car thing..
Do you still have your e-brake pulled when you are trying to put it in gear? For some reason on my car I have to release the ebrake and then try again and it will go into gear.
Multi-paradigm
Re: (WongFeihung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung »</TD></TR><TR><TD CLASS="quote">
um..thats also debatable..about the whole warming up your car thing..</TD></TR></TABLE>
Yeah...
(says every tech at Consumer Reports's and Car & Driver.)
Yeah...
CiViC_SOHC
16
03-17-2007 10:06 AM
