Help Car Died, Fuel Pump?
Old 11-29-2003, 07:36 PM
mikefxu's Avatar
Default Help Car Died, Fuel Pump?
alright my car died today on the way to work its a 96 CX hatch completely stock. it just died i tried turning it over but it would not start, seems like no fuel. ok when i turn the key i hear fuel pump come on then i hear click under dash and fuel pump turns off then i go to turn over engine and fuel pump turns back on after cranking awhile i hear a thump i think it is the fuel pump in the tank. if i gas it all the way while starting it will start for a second and run really rough. while all this is going on alot of clicking under the dash going on i assume fuel relays.
any help of possible problem would be appreciate, iam thinking fuel pump?
thank you ahead of time
mike
Old 11-29-2003, 08:00 PM
Moderator
chad's Avatar
Default Re: Help Car Died, Fuel Pump? (mikefxu)
main relay....
Old 11-29-2003, 08:37 PM
mikefxu's Avatar
Default Re: Help Car Died, Fuel Pump? (chad)
http://www.hondaautomotivepart...IN%29
which one its it?
Old 11-29-2003, 08:38 PM
Chris93Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">main relay....</TD></TR></TABLE>
Yep, like $55 new from Honda.
Old 11-29-2003, 08:44 PM
mikefxu's Avatar
Default Re: Help Car Died, Fuel Pump? (Chris93Si)
number 009 for $52.10/$39.07???
Old 11-29-2003, 10:53 PM
mikefxu's Avatar
anyone?
Old 12-01-2003, 02:22 AM
mikefxu's Avatar
well i got my car back to my house last night and check to make sure the timing belt wasnt broken, it wasnt. then i pulled the spark plugs, the plug closest to the timing belt was difficult to remove and when it came out it looked horrible it seems as if the piston slammed into the plug and now all the material below the threads is in that cylinder. iam going to pull the head and see what happened. it almost seems as if there is a hole in the piston from the view through the plug hole but who knows. it seems to me a mechanical failure, could a electrical failure cause this type of damage?
thankyou
cleo7
01-23-2013 08:53 AM
hatchBK4life
08-02-2010 05:11 PM
Jimster480
17
10-27-2009 06:57 AM
iNDyCRX
04-24-2008 12:54 PM
nicko360
15
01-17-2007 06:22 PM
Quick Reply: Help Car Died, Fuel Pump?
