HELP asap! clutch wont disengage
Old 02-24-2007, 05:31 PM
hndacord02's Avatar
Default HELP asap! clutch wont disengage
I have a 99 civic si. When i push the clutch in, i have to push the pedal all the way down to the floor, and really push it against the floor to disengage it. And when i let it out, the clutch pedal doesnt come back up all the way! please help me out asap with what is goin on!! thanks...
Old 02-24-2007, 05:55 PM
RCautoworks's Avatar
Default Re: HELP asap! clutch wont disengage (hndacord02)
Air in the lines, try bleeding the system. Look under the dash, make sure the peddle is not broken, usually only occurs with ef's because of the cable pressure though.
Old 02-24-2007, 08:09 PM
MiX
MiX's Avatar
Default Re: HELP asap! clutch wont disengage (RCautoworks)
just replace the slave cylinder. they are pretty cheap from the parts store. Then bleed it and it should solve your problem.
Old 02-25-2007, 12:45 AM
hndacord02's Avatar
Default Re: HELP asap! clutch wont disengage (MiX)
aight, this wouldnt have anything to do with needing a new clutch at all would it? what would those "symptoms" be? thanks for the help guys
Old 02-25-2007, 02:14 AM
yoej8's Avatar
your clutch should be fine, symptoms of a dead clutch would be like you put it in gear and the car barely moves.
Your problem most likely lies within the hydrolic system. Look down by your clutch and make sure it doesn't have stuff leaking from it. If it doesn't just proceed to bleed the clutch lines. If the problem still persists, you might have to change out either the master or slave clutch cylinder.
Old 02-25-2007, 02:30 AM
hoya_10fintec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiX &raquo;</TD></TR><TR><TD CLASS="quote">just replace the slave cylinder. they are pretty cheap from the parts store. Then bleed it and it should solve your problem. </TD></TR></TABLE>
my friend had the same problem... I just replaced the slave cyl.
Old 02-27-2007, 05:05 PM
hndacord02's Avatar
Default Re: HELP asap! clutch wont disengage (hoya_10fintec)
ok, it was the slave and the master cylinder that went on it! i got it all fixed, and running right
Old 02-27-2007, 07:17 PM
d16z6 eg6
09-16-2009 02:36 PM
Streetneon2185
09-17-2007 03:24 PM
KRAP DIVAD
09-04-2005 05:10 PM
ls95hatch
05-24-2003 09:34 PM
Quick Reply: HELP asap! clutch wont disengage
