HELP!!! 95 Civic hood wont close and lock (hitting radiator) - Honda-Tech
Old 07-01-2012, 09:56 PM   #1
Default HELP!!! 95 Civic hood wont close and lock (hitting radiator)
OKay so i bought a new hood for my 95 civic and when i try to close it it seems like its hitting the radiator or something???the hood wont close all the way to lock i was thinking i maybe need a new radiator support or sumthing when i got the car the hood they had on it was beat up in the front like they used a hammer to smash the front part of the hood to get it to fit and lock correctly NEED HELP
DjAccurate is offline   Reply With Quote
Old 07-02-2012, 04:44 AM   #2
redm3turbo's Avatar
Default Re: HELP!!! 95 Civic hood wont close and lock (hitting radiator)
make sure the hood release mechanism is down.....is your hood latch cable good? if not push on it to make sure it releases. that or look at the mechanism (where the hood latches) itself and make sure its in the "open" setting and not the "closed" setting.
redm3turbo is offline   Reply With Quote
Old 07-02-2012, 05:11 AM   #3
The Grumpiest
grumblemarc's Avatar
Pics please.
grumblemarc is offline   Reply With Quote
Old 07-02-2012, 08:06 AM   #4
The latch is good i will post some pics so you guys can have a better look
Old 07-02-2012, 09:36 AM   #5
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
I had this issue after installing a 2 row rad into my hatch because the pegs on the bottom of the rad. The pegs go into rubber pieces that stick in cup like tabs. Mine didn't fit in there perfectly so it caused me to loose 1/2-1" of clearance on top.
speedjunkie_g35 is offline   Reply With Quote
Old 07-02-2012, 11:56 AM   #6
did you buy the right hood? a 2 door hood will fit on a sedan, but its a tiny bit shorter... so a sedan hood on a 2 door could mean its longer which could make it hit the radiator...
ozh_hawaiian is offline   Reply With Quote
Old 07-02-2012, 12:13 PM   #7
I bought the hood from a junkyard i have a 2door civic But on the recipt it says a hood for a civic hatchback are there both the same?
Old 07-02-2012, 12:52 PM   #8
WOW thanks speedjunkie_g35 i check the bottom of the rad and those little cup things were all worn out and uneven problem solved hood closing and opening fine
Old 07-02-2012, 01:52 PM   #9
fml760's Avatar
replace everything...on radiator support
fml760 is offline   Reply With Quote
hood wont close helpp xJDMCx Honda Civic / Del Sol (1992 - 2000) 4 08-20-2009 03:25 PM
replacement hood latch?!? please help prf0188 Honda Civic / Del Sol (1992 - 2000) 3 03-03-2008 09:14 AM
Cf hood latch won't latch! initialvtec Audio / Security / Video 5 11-17-2004 11:04 AM
cf hood won't latch!!! HELP I TRIED EVERYTHING! initialvtec Acura Integra 18 11-09-2004 08:19 PM
Need Help! Hood wont lock gubuju Honda Accord (1990 - 2002) 2 02-28-2004 04:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
