Headlight reminder beeper - Honda-Tech
Old 05-16-2005, 01:20 PM   #1
bdptcob's Avatar
Default Headlight reminder beeper
I have a 2002 Civic. Not too long ago the headlight reminder beeper stopped working. My wife for whatever reason cannot remember to turn them off and it almost resulted in a dead batter 300mi away from home. I assumed it was a fuse. I checked the user manual (and did a search on the forums) but did not see any fuse slot title anything remotely close to beeper or reminder. I could check every fuse, time consuming as it may be, but I wanted to ask here first. Anyone else experience anything along these lines? Thanks.
bdptcob is offline   Reply With Quote
Old 05-16-2005, 01:22 PM   #2
Cypher0117's Avatar
Default Re: Headlight reminder beeper (bdptcob)
i have a similar concern unless a 94 civic dx doesn't come w/ a headlight beeper
Cypher0117 is offline   Reply With Quote
Old 05-16-2005, 02:16 PM   #3
Default Re: Headlight reminder beeper (Cypher0117)
Quote:
never came with it, 96 up civics do
longbeachpurplecivic is offline   Reply With Quote
Old 05-16-2005, 02:30 PM   #4
BS 22's Avatar
Default Re: Headlight reminder beeper (longbeachpurplecivic)
I've left my headlights on twice, both times the battery died just because I don't have that reminder thing. Oh well, doesn't happen to me anymore.
BS 22 is offline   Reply With Quote
Old 05-16-2005, 02:35 PM   #5
Methuselah's Avatar
it's an easy add-on... go to radio-shack and get a simple 12 volt beeper and wire one end to the parking-lights (+12 when lights are on) and the other to the dome-light switch for the door (grounds when the door opens).
When the door opens and the lights are on, it beeps.
good luck.
Methuselah is offline   Reply With Quote
Old 05-16-2005, 02:49 PM   #6
IHateJDM's Avatar
Default Re: Headlight reminder beeper (BS 22)
Quote:
I've done that so many times, lol. damn 93. at least its a honda, anything heavier and you can't push it off by yourself.
IHateJDM is offline   Reply With Quote
Old 05-16-2005, 02:52 PM   #7
Electrician
Deemeetree's Avatar
Default Re: Headlight reminder beeper (Methuselah)
good luck.
This sounds like a good way, but he already has one factory installed.
You'll need to troubleshoot it on why it doens't beep. Make sure the fuse for it is in good condition. Make sure none of the wires that goes to the doors fell off (the one that are in the door jamb to trigger the interior lights or beeper).
Deemeetree is offline   Reply With Quote
Old 05-16-2005, 03:03 PM   #8
civiccoupe94's Avatar
Default Re: Headlight reminder beeper (Dimitri_EG8)
wheres the dome light switch wire? and how much is the beeper at radio shack?
civiccoupe94 is offline   Reply With Quote
Old 05-16-2005, 03:50 PM   #9
Bcuz's Avatar
Your problem is caused by the recall on your vehicle, take your car into a honda dealership. They will replace your switch which is probably burnt by now. It's called the "combo light switch recall", they'll know what you mean. Good Luck.
Bcuz is offline   Reply With Quote
Old 05-16-2005, 08:38 PM   #10
bdptcob's Avatar
Default Re: Headlight reminder beeper (Bcuz)
Thank you very, very much.
Old 05-16-2005, 08:43 PM   #11
BS 22's Avatar
Quote:
Badass!
Thanks for the answers guys
<--- taking it to honda this weekend
Old 07-08-2006, 12:16 PM   #12
the beeper you can buy from walmart...
does it have 2 positives and one ground?
1 goes to the headlight...
1 to the ignition (or windshield wiper)...
and one to the ground?
BoBakTXL is offline   Reply With Quote
Old 07-08-2006, 02:32 PM   #13
commotion's Avatar
Default Re: Headlight reminder beeper (BoBakTXL)
i have a 1995 civic and mine beeps
commotion is offline   Reply With Quote
Old 07-08-2006, 09:11 PM   #14
AIRIC's Avatar
Default Re: Headlight reminder beeper (commotion)
Quote:
i have a 93 civic and mine beeps when the door is open and the keys are in the ignition
AIRIC is offline   Reply With Quote
HOW TO: Remove the key in ignition/headlights on warning beeper. slowexcoupe Honda Civic / Del Sol (1992 - 2000) 35 01-28-2015 10:43 PM
Headlight beeper not working. sarahyost Acura Integra 26 12-07-2011 08:36 PM
honda civic 94 EH9 seat belt and head light chime problem faraz Honda Civic / Del Sol (1992 - 2000) 14 12-07-2011 08:34 PM
headlight warning beeper question KINGVEM^^ED6 Honda CRX / EF Civic (1988 - 1991) 6 10-04-2011 06:02 AM
99 ek fuse box diagram (searched, go this: Search failed. Please try again later. ) Mr_Si-R Honda Civic / Del Sol (1992 - 2000) 7 08-01-2007 12:30 PM
Tags
1995, 2000, 94, accord, acura, beep, civic, fuse, headlight, honda, light, prelude, reminder, replace, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
