Headgasket or Seals?
On some occasions I get white smoke out of the exhaust upon starting, and I checked my coolant today and I was bone dry. There is a leak of oil in the front pass. side where the headgasket is. It has caused a build up of oil around the bottom two bolts of my manifold. Seals or headgasket?
Re: Headgasket or Seals?
im going to say the head gasket.white smoke right.....u could take out the spark plugs and see if there is coolant in there
or u need a new valve gasket
yea white smoke but it doesnt happen all the time. the car is sluggish too, not sure if thats do to needing a tune though. I'm getting it tuned on the 24th of august so I have time to figure it out, just gotta get it done. Is there anything I can do to test if its a headgasket without tearing it apart
do a leak down test. But it def sounds like your head gasket is leaking between cylinders. Check your oil and see what color it is. Sometime a headgasket leak between cylinders wont cause coolant to go to the oil but sometimes its a good indication of a bad head gasket
DRoylflush
11
04-10-2011 02:11 PM
