Header benefits on a d16y8?? - Honda-Tech
Old 06-17-2005, 04:59 PM   #1
G-CIV's Avatar
Default Header benefits on a d16y8??
Do any of you guys know if it will make much of a difference in my 97 civic coupe ex coupled with intake and exhaust piping at 2.25 and a high performance muffler to place a header on it?
I've been considering the DC Sport 4-2-1 two piece, and does anybody know much about that header(clearence, quality,etc...)
Will it make much of a difference in my power????
Modified by G-CIV at 5:15 PM 6/17/2005
G-CIV is offline   Reply With Quote
Old 06-17-2005, 07:40 PM   #2
Default Re: Header benefits on a d16y8?? (G-CIV)
If you search at all you will find something usefull. Take a note: typically, using an aftermarket header will be one of the most noticable power gains. This is true for practically any make or model. Non FI of course.
Revolver is offline   Reply With Quote
Old 06-17-2005, 08:13 PM   #3
G-CIV's Avatar
sweet, thnx for the info,...does an aftermarket intake manifold make much of a difference? like the skunk 2 one?
Old 06-17-2005, 08:25 PM   #4
Quote:
Not as notable. The intake manifold goes up in effectiveness the more HP you create
Old 06-27-2005, 11:14 AM   #5
G-CIV's Avatar
Default Re: Header benefits on a d16y8?? (Revolver)
so should i buy some haeders? i mean is the difference that i will notice be worth the $250 that i would spend on some header?!
Old 06-27-2005, 11:24 AM   #6
AutoXer's Avatar
You need to spend quite a bit more time researching this site, because you've asked alot of general questions so far.
You will spend alot of money on bolt ons for that engine, and maybe gain 10hp. It's not a good $/hp benefit; and you probably won't notice any difference on the street.
You should make a plan of ultimately where you want to go. If you really want to make some power, you'll either need to build or go FI, that's where these extra parts start giving some gains by optimizing your system.
I'd wait a while, figure out what you really want to do with the car, then start researching what parts will work best for your needs and application. But if you really just want to mod your car to mod or whatever, then go ahead, but you may realise later that you wasted the money and have to buy the parts all over again.
AutoXer is offline   Reply With Quote
Old 06-27-2005, 12:26 PM   #7
EricUSC's Avatar
Default Re: Header benefits on a d16y8?? (AutoXer)
A 4-2-1 header is the way to go for daily driving for it gives the best mid-rpm gains. A 4-1 header gives better high-rpm gains, but not much mid-rpm gains if any. You will probably get at most 5 hp from a 4-2-1 header on a D16Y8. Here is a dyno graph from a Comptech 4-2-1 header on a D16Y8:
http://www.comptechusa.com/ima...t.pdf
EricUSC is offline   Reply With Quote
Looking for San Diego North County JDM Shops GCIV Honda Civic / Del Sol (1992 - 2000) 6 10-27-2005 07:40 AM
Cam benefits? G-CIV Honda Civic / Del Sol (1992 - 2000) 8 06-30-2005 06:13 AM
5gCiv ex Engine decisions Syphon Honda Civic / Del Sol (1992 - 2000) 1 07-16-2003 12:55 PM
power steering? 4gciv Honda CRX / EF Civic (1988 - 1991) 4 12-20-2002 04:55 PM
AEM intake sizing question Cory man Tech / Misc 2 03-04-2002 03:40 PM
Tags
41, 421, aftermarket, benefits, charts, d16y8, difference, dyno, gains, give, header, headers, hp, intake, makes, manifold
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
