Which Head should i use. ITR/CTR stock vs. B16 worked
Old 12-15-2010, 01:54 PM
terronb20ek's Avatar
Default Which Head should i use. ITR/CTR stock vs. B16 worked
ok guys so i recently bent a few valves in my stock b16 head so i am on the look out for another, more powerful, b16 head.. so far i cme across two sweet deals but not to sure what to choose.
Pr3-4 casting
itr/ctr internals
stock b16 intake manifold and fuel rail. $400 from a local
VS.
Pr3-3 casting
B16 head
Blox Intake manifold (identical to ITR manifold)
Rocket Motorsports Dual Valve Springs and Titanium Retainers
Supertech Black nitrate Coated Valves
ITR/CTR cams
3 angle valve job
golden eagle fuel rail
type r throttle body $600
i thought the second pr3-3 casting head would pu out more horses on my b16 block. which one do you guys think s more powerful?
Old 12-15-2010, 01:56 PM
-__-'s Avatar
Default Re: Which Head should i use. ITR/CTR stock vs. B16 worked
the second choice hands down. its a good deal. i could take that stuff and make about $1000 off of it. second choice 100%. u want those cams
Old 12-15-2010, 02:22 PM
Vicep3's Avatar
I'd go wid the 2nd choice. It's totally worth it. Only $200 more n u get better parts
Old 12-15-2010, 04:29 PM
NotAJDMFanBoy's Avatar
The second one. The ITR/CTR heads only have a very mild port job. I'd look into those titanium retainers though. Some are known to be soft and meant for racing only. Fine for their intended purpose, but not durable for a DD.
Old 12-25-2010, 08:39 AM
thanks guys... now how about
second choice
vs.
b16 head
Ported and polished
3 angle valve job
supertech valves, springs, and retainers
gsr cams? $500
stock intake, fuel rail, injectors
Does the port job really out weigh the second choice? Would the port job in this head really make a big difference?
P.S. (NotAJDMFanBoy) looked into it and yeah they are racing retainers.. guy had the head on his gsr boosted and pulled 10k revs
Old 12-25-2010, 08:43 AM
HondaTom87's Avatar
I would go with the ported and polished head with the supertech setup but I would def have it checked out by a machine shop and flowbenched if you can find someone to do that for you.
the ported will make more power if it is a good port job. and you can always find a used blox intake manifold for dirt cheap.
Old 12-25-2010, 08:50 AM
Thanks for the input.. i also forgot to mention it needs valve seals as well. but thats easy to tackle right?
Old 12-25-2010, 09:04 AM
ef8-dc2619's Avatar
i would go with pr3-3 with itr cams. gsr cams<itr cams
Old 12-25-2010, 09:06 AM
thankz for the input bro....ifigured that. its that port job thats getting me stuck on this lol...
Old 12-25-2010, 09:07 AM
ALSO THE SECOND CHOICE HAS ON 7K AFTER REBUILD!
Old 12-25-2010, 09:18 AM
justin91's Avatar
yeh def go with second choice pr3-3. If they ported that other head too much, it will hurt performance for sure(might be too much for ur application) + it needs valve stem seals(easy fix but y deal)
honda_12V
09-16-2012 11:04 PM
92integraVTECgsr
Southeast (Sales)
02-11-2011 05:44 AM
Deetz
11-19-2004 11:57 PM
dfoxengr
33
12-14-2003 06:00 PM
BoostinDC2
09-18-2001 07:03 PM
Quick Reply: Which Head should i use. ITR/CTR stock vs. B16 worked
