Head Oil Control Orifice - Missing o-ring? - Honda-Tech
Old 01-31-2007, 02:47 AM   #1
Achenar's Avatar
Default Head Oil Control Orifice - Missing o-ring?
I'm replacing the head gasket on my B16A2.
Per the HELM instructions, I pulled out the head oil control orifice to clean, and replace the o-ring ... however, much to my surprise, there wasn't an o-ring!
Am I correct to assume foul-play?
I can't verify all of the history of this motor, and I suspect at some point, someone replaced the head ... most likely re-using the head gasket and bolts (which is why the damn thing has been leaking so badly with only ~100k miles on it.
I just can't imagine why someone would pull out the orifice without at least re-using the o-ring.
-a
Achenar is offline   Reply With Quote
Old 01-31-2007, 10:58 AM   #2
Achenar's Avatar
Default Re: Head Oil Control Orifice - Missing o-ring? (Achenar)
Old 01-31-2007, 11:00 AM   #3
fmrprojects's Avatar
if you can get it just put it in. and you dont have to replace all the bolts, just get the head resurfaced and get a new head gasket.
fmrprojects is offline   Reply With Quote
Old 01-31-2007, 06:00 PM   #4
Achenar's Avatar
Default Re: Head Oil Control Orifice - Missing o-ring? (fmrprojects)
Heh, turns out the alternator o-ring was also missing!
No wonder this thing has been leaking so much oil!
-a
Old 01-31-2007, 07:33 PM   #5
Kafelatte's Avatar
alternator o-ring? do you mean the distributor
Kafelatte is offline   Reply With Quote
Old 02-01-2007, 02:28 AM   #6
Achenar's Avatar
Default Re: Head Oil Control Orifice - Missing o-ring? (kay20adc2)
My bad ... it's been a long day
-a
Gaskets, Seals, & O-Ring's Oh my! B20VSi2000 All Motor / Naturally Aspirated 1 05-16-2016 05:38 AM
1999 Civic "Oil Control Orifice" in service manual conflicts with parts catalog. Tim1959 Honda Civic / Del Sol (1992 - 2000) 16 06-03-2015 11:31 AM
How do you remove head oil control orifice? B19CivicHB Tech / Misc 12 07-03-2009 08:49 PM
Need Part Number: Oil control orifice o-ring ridgeapd Honda CRX / EF Civic (1988 - 1991) 3 06-29-2009 02:56 AM
Oil orifice o-ring? all-mtr-teg All Motor / Naturally Aspirated 9 09-11-2007 06:17 AM
Tags
accord, acura, civic, control, honda, i, integra, made, mine, missing, oil, orafice, orifice, ring, rl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
