Head gasket for y8 block and z6 head?
Old 06-09-2008, 06:10 PM
justinCO's Avatar
Default Head gasket for y8 block and z6 head?
I have a d16y8 block, with a d16z6 head bolted up, I should be using the y8 head gasket, right? I just want to confirm for this block/head combo. My current setup is leaking coolant at the head gasket, using y8 gasket, so that is why I want to confirm it is the right one.
Justin
Old 06-09-2008, 06:35 PM
CivicSpoon's Avatar
Yup, it's the right one to use. Are you using the right head bolts though? 9 '88-'95 head bolts and 1 '96-'00 head bolt?
Old 06-09-2008, 08:31 PM
justinCO's Avatar
Default Re: (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon &raquo;</TD></TR><TR><TD CLASS="quote">Yup, it's the right one to use. Are you using the right head bolts though? 9 '88-'95 head bolts and 1 '96-'00 head bolt?</TD></TR></TABLE>
Umm, you sure about that? I thought it was the other way around? I used 9 y8 bolts (96-00) and 1 z6 bolt (92-95). And actually, I'm not even sure the builder used the z6 bolt I gave them...so far as I know they used all 10 y8 bolts...
Justin
Old 06-10-2008, 08:53 AM
CivicSpoon's Avatar
Default Re: (justinCO)
You're right, I had a brain fart or a temporary moment or dyslexia. You use the head bolts for the block you're using. But that 1 Z6 bolt will make a difference, since it's longer than the '96-'00 bolts.
Old 06-10-2008, 09:16 AM
justinCO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon &raquo;</TD></TR><TR><TD CLASS="quote"> You're right, I had a brain fart or a temporary moment or dyslexia. You use the head bolts for the block you're using. But that 1 Z6 bolt will make a difference, since it's longer than the '96-'00 bolts.</TD></TR></TABLE>
Right, and I did get confirmation that the z6 stud was used in the solenoid spot. Well, out of ideas, car is on trailer as we speak and I'm taking it in to the builder. Hopefully I'll find out what is wrong soon.
Justin
eg6civic1538
02-23-2009 08:27 AM
Manny86
05-22-2007 10:17 AM
Lightweight Boost
01-01-2007 01:19 PM
NMBnutz03
04-15-2004 05:28 PM
4gvtec
09-15-2002 10:36 PM
Quick Reply: Head gasket for y8 block and z6 head?
