Head gasket problem - Honda-Tech
Head gasket problem
Old 04-25-2010, 11:07 AM   #1
Default Head gasket problem
I currently own a 94 civic with a d15b vtec engine. I recently blew 2 head gaskets in the space of two days. Any suggestions on what could be the cause of this. Any help would be greatly appreciated.
anthony g is offline   Reply With Quote
Old 04-25-2010, 11:09 AM   #2
nothing_shocking's Avatar
Default Re: Head gasket problem
Not cleaning out the bolt hole good enough, not torquing bolts right, not re-torquing after a couple heat soaks, junk head gaskets.
nothing_shocking is offline   Reply With Quote
Old 04-25-2010, 11:51 AM   #3
RICKSAUTOMOTIVE's Avatar
probably you have a warped head or deck. did you get a valve job or take the head to the machine shop to be inspected? this is a must when ever you do the valve job. also replace the head bolts too. this is recommended when you buy the gasket for a reason. they do stretch sometimes. better safe than sorry. also i personally recommend dealer head gaskets. yes i know they are a whole 30 bucks more but i sleep better and my cars run for a fey years before i have to do them again...if i ever do. and of course what nothing shocking said is also true. as is the torque wrench you used. was the torque wrench calibrated correctly? has it been stored in a very well manner? or banged around in a tool box and dropped often? mine are in a foam padded drawer in my box with other sensitive tools
RICKSAUTOMOTIVE is offline   Reply With Quote
Old 04-27-2010, 06:15 PM   #4
Thanks for the help guys. I had 2 head bolts that were damaged. Will change all the head bolts and see what happens from there.
Old 04-27-2010, 06:45 PM   #5
i would also get the head checked for warpage
ThatGuy522 is offline   Reply With Quote
Old 04-27-2010, 06:48 PM   #6
MiG-21 superfan
builthatch's Avatar
absolutely check the deck and head for warpage at this point, despite your findings about the bolts. this can be accomplished with a legitimate straightedge and feeler gauge, but ideally it should be perfectly flat with the straightedge.
builthatch is offline   Reply With Quote
Head Gasket.. anonnonator Honda Civic (2001 - 2005) 7 07-16-2008 03:12 PM
Installing a head gasket on a gsr HONDA RR Acura Integra 7 04-12-2005 12:57 PM
Head Gasket?? 92-LS-Civic Acura Integra 1 10-03-2004 08:14 PM
SOHC head gasket on ZC? crxhybrid85 Honda CRX / EF Civic (1988 - 1991) 5 08-08-2004 11:21 AM
using only middle head gasket? hybridhatch90 Honda CRX / EF Civic (1988 - 1991) 5 09-02-2002 08:48 PM
Tags
2000, civic, d15b, deck, gasket, head, honda, problem, problems, torque, warpage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
